製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Supports 2.4G/5GHz dual-band
  • Wireless PHY rate can reach up to 867Mbps
  • IEEE Standards: IEEE 802.11a/b/g/n/ac
  • Form factor: M.2 2230 generic A key or E key
  • Connect to external antenna through MHF4 connectors
  • Power Supply: DC3.3V±0.2V power supply
  • Supports Linux, Windows 10/11, etc.
仕様
Chipset
RTL8822CE - CG
WLAN Standards
IEEE802.11a/b/g/n/ac
BT Specification
Bluetooth Core Specification v5.0/4.2/2.1
Host Interface
PCI Express 2.1 for WLAN & USB2.0 FS for Bluetooth
Antenna
Connect to the external antennas through MHF4 connector
Dimension
M.2, 30*22*2.15mm (L*W*H)
Power Supply
DC 3.3V±0.2V @ 1000mA (Max)
Operation Temperature
-20°C to +70°C
Operation Humidity
10% to 95% RH (Non - Condensing)
ハードウェア概要
ドキュメント
認証
HSCODE8517799000
USHSCODE8517620090
UPC
EUHSCODE8517180000
COOCHINA
部品リスト
Wireless-RTL8822CE
x1
RTL8822CE Wireless NIC, 2.4G/5GHz Dual-Band WiFi 5, Bluetooth 5.0, Compatible with Jetson Orin
SKU 114993556
The RTL8822CE is a compact Dual-band WLAN+Bluetooth Combo M.2 Card that integrates a 2T2R Dual-band WLAN subsystem with PCI Express controllers and a Bluetooth v5.0 subsystem with USB support. Compatible with IEEE 802.11 a/b/g/n/ac standards, it delivers a maximum PHY rate of up to 867 Mbps and supports Bluetooth dual mode (v5.0/v4.2/v2.1). Ideal for high-performance wireless and Bluetooth connectivity for using with embedded devices such as reComputer J4012.
JPY¥1108.00
Customize Design reComputer
