おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • High-Performance Chipset
Built on the powerful combination of EFR32MG24 +ESP32D0WDR2, Dongle Max delivers outstanding processing capability and rock-solid stability. Give you more performance headroom and future expansion possibilities.
  • Flexible Connectivity Options
Supports Ethernet, Wi-Fi, and USB connections, giving you the freedom to deploy Dongle Max wherever it fits best. Even when your Dongle is far from the router, wireless access keeps it connected.
  • Web-Based Management Interface
Access a dedicated web console that brings together device status, settings, logs, and alerts — all in one place. Monitor uptime, troubleshoot, or fine-tune behavior without command lines.
  • Easy Firmware Management
Switch or update firmware right from the web interface — no disassembly or manual flashing required. Whether using it as a Zigbee coordinator, router, or Thread RCP, Dongle Max makes it simple.
  • Reliable Build Quality
Equipped with 5dBi dual adjustable antennas for enhanced 360° signal coverage. The aluminum housing is built to last, tested with 24-hour salt spray, and certified by CE, FCC, and RoHS — ensuring long-term reliability and peace of mind.
仕様
ProductSONOFF Dongle Max Zigbee/Thread PoE Dongle
ModelDongle-M
ConnectionEthernet/Wi-Fi/USB (*Supports PoE)
Antenna Gain5dBi
Number of Antennas2
SocEFR32MG24+ESP32D0WD
Additional CapabilitiesWeb Console / Webhooks / AP Hotspot / Wireguard
Supported PlatformsHome Assistant / OpenHAB / Z-Wave JS
Cable IncludedUSB Type-C cable (1m)
Input5V⎓1A for Type C or 48V⎓ 0.25A for PoE port
Wireless connectionsZigbee 3.0, Wi-Fi IEEE 802.11b/g/n 2.4GHz
Working temperature-10°C~60°
Casing materialsAluminum, PC+ABS
Network interface typeRJ45
ColorDim gray
ハードウェア概要
用途
  • Designed to connect Zigbee (and Thread) sub-devices to open-source platforms such as Home Assistant and Zigbee2MQTT
  • Ideal for users who need flexible installation and wireless/Ethernet access, allowing the coordinator to be placed where signal coverage is optimal (living rooms, bedrooms, basements, warehouses, etc.)
  • Suitable for advanced users and development scenarios requiring PoE, dual antennas, local Web Console, firmware switching, MQTT, Webhooks, and VPN
  • Supports multiple operating modes: Zigbee Coordinator, Zigbee Router, Thread RCP, or MultiPAN for versatile smart home networks
ドキュメント
認証
HSCODE8517629990
USHSCODE8517620010
UPC
EUHSCODE8517180000
COOCHINA
部品リスト
SONOFF Dongle Max Zigbee/Thread PoE Donglex1
Scew accessory packagex2
USB Type-C cable (1m)x1
Bracketx1
Double-sided tapex2
Quick guidex1
SKU 100029798
SONOFF Dongle Max is a Zigbee gateway developed based on ESP32D0+EFR32MG24, model Dongle-M, designed to connect Zigbee sub-devices to open-source platforms like Home Assistant and Zigbee2MQTT. It supports POE power supply and offers multiple connectivity options, making it adaptable to various usage scenarios.
USD$42.90
product.detail.alsoAdd.title
