製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
OCELL is a 0.5 inch OLED module designed as a  Arduino shield and also available for other  micro controllers . It is the smallest Arduino display module you can find so far.
You could connect it to Ardunio micro directly without doing any PCB layout and also available for other controllers . It is a good choice for a DIYer to make a project which need a tiny COOL OLED display.
  • The smallest size in all Arduino display modules so far.
  • Very high contrast and brightness.
  • Very low power consumption
  • No backlight required
  • Supported by U8glib library
High light
These OLED displays are small, only about 0.5" diameter, but very readable due to the high contrast (450cd/m^2 brightness). This display is made of 60x32 individual white OLED pixels, each one is turned on or off by the controller chip. Because the display makes its own light, no backlight is required. This reduces the power required to run the OLED and is why the display has such high contrast and very low power consumption.
  • PCB dimensions: 17.8mm X 15.5mm
  • Screen size: 0.5 (inch) W. H: 15.30x10.20 mm
  • Color: Monochrome (white)
  • OLED  type: PM -OLED
  • OLED driver: LD7032
  • Pixels : 60 x 32
  • Contrast: 2000: 1
  • Communication: SPI, I2C
Note
  • 1 pc OCELL includes: 1x module PCB , 1x OLED display , 1x10 pins header
  • Does not include: Arduino
Documents
認証
HSCODE8531200000
USHSCODE8531200020
UPC841454116912
EUHSCODE8531202090
COOCHINA
技術詳細
Dimensions80mm x100mm x3mm
WeightG.W 5g
BatteryExclude
0.5 Inch OLED display Arduino shield
SKU 308020004
The smallest size in all Arduino display modules so far. Very high contrast and brightness. Very low power consumption No backlight required Supported by U8glib library
JPY¥2375.00
廃番
