製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • A Mini Smart Device Board, Ready for Your Next Project
    For many small hardware projects, the hard part is not starting the controller. It is turning a screen, touch input, microphone, sensors, battery, and buttons into a small device that feels complete and usable. This board already brings these key parts together, so you can spend more time building the actual experience: designing the UI, reading data, adding interaction, and connecting to the network, instead of wiring modules one by one.
  • Make Your Projects That Look and Feel More Finished
    The 1.47-inch color touch display helps your project move beyond serial output, LEDs, or rough test setups. You can build menus, status pages, icons, buttons, sensor dashboards, and simple animations, making your prototype easier to show, use, and share. For demos, customer presentations, classroom projects, and maker builds, it helps the final result feel much more complete.
  • Touch, Voice, and Motion in One Small Board
    This board does more than show information. It also gives your project multiple ways to respond to the user. The touch screen is great for menus and controls. The microphone can be used for recording, sound triggers, or voice interaction. The IMU can detect orientation, shaking, flipping, and motion. With these built in, you can build a small device that can “listen”, “move”, and respond to touch, not just display data.
  • Built for Connected AIoT Ideas
    Powered by XIAO ESP32-S3 Plus, this board is a strong fit for small devices that need Wi-Fi and Bluetooth connectivity. Build a desktop weather screen, server status monitor, Home Assistant panel, smart home touch controller, cloud data display, or a mini AIoT node that connects sensors with online services.
仕様
SpecificationXIAO 1.47'' IPS Display(ESP32-S3)XIAO 1.14'' IPS Display(ESP32-S3)XIAO 0.96'' IPS Display(ESP32-S3)
PositioningTouch & Full InteractionSensing & ExpansionUltra-Compact
Core ControllerSeeed Studio XIAO ESP32-S3 Plus
ProcessorESP32-S3R8, Dual-Core, up to 240 MHz
Memory8 MB PSRAM + 16 MB Flash
Wireless2.4 GHz Wi-Fi + BLE 5.0
Display1.47" IPS TFT1.14" IPS TFT0.96" IPS TFT
Resolution172 × 320135 × 24080 × 160
Display DriverJD9853AST7789ST7789
TouchCapacitive TouchNoNo
6-Axis IMUYes
PDM Digital MicrophoneYes
MicroSD Card SlotYesNoNo
Grove I2C ConnectorNoYesNo
User Buttons232
Battery Connector2-pin JST, 3.7 V LiPo
Battery MonitoringBattery voltage monitoring via D16 ADC; battery level can be estimated from the measured voltage.
Battery status detection is not supported.
Expansion Interfaces1x I2C Interface
1x I2S Interface
1x JTAG Interface
2x User Button Interface
1x I2C Interface
1x I2S Interface
1x JTAG Interface
3x User Button Interface
1x I2C Interface
1x I2S Interface
1x JTAG Interface
Board Size26.4 × 51.4 × 12.6 mm26 × 48 × 10.6 mm18.8 × 43.6 × 10.6 mm
Best ForTouch UI, portable HMI, local media & data loggingSensor dashboards, Grove projects, physical controllersTiny IoT devices, wearables, status displays
ハードウェア概要
  • Onboard
用途
  • Mini Desktop Dashboard
  • AI Voice Assistant & Agent Terminal Prototype
  • Smart Home Touch Controller
  • Digital Pet and Interactive Toy
認証
HSCODE8543709990
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
部品リスト
XIAO 1.47'' IPS Display(ESP32-S3)×1
2.4GHz FPC Antenna A-02 for XIAO ESP32-S3×1
XIAO 1.47'' IPS Touch Display(ESP32-S3)
SKU 100069905
It is a ready-to-use mini smart device development board. It brings a touch display, microphone, IMU, MicroSD card slot, battery connector, and user buttons together with the pre-soldered XIAO ESP32-S3 Plus, so you can start building small smart hardware with screen, touch, voice, motion sensing, and wireless connectivity without wiring many separate modules.
It is ideal for mini dashboards, smart home controllers, voice interaction devices, digital pets, small control panels, and AIoT projects.
XIAO Dev Board
Display Size
JPY¥3150.00
