おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • A Mini Smart Device Board for Portable Projects
    If you want to build a small device that can be held, worn, or built into an enclosure, you usually need a screen, touch input, buttons, battery support, sensors, and Bluetooth connectivity. This board brings these key parts together, so you can focus on the project itself: building the UI, adding interaction, reading motion, and connecting to a phone or other Bluetooth devices, instead of starting with many separate modules and wires.
  • Make Your Projects That Look and Feel More Finished
    The 1.47-inch color touch display helps your project move beyond serial output, LEDs, or rough test setups. You can build menus, status pages, icons, buttons, sensor dashboards, and simple animations, making your prototype easier to show, use, and share. For demos, customer presentations, classroom projects, and maker builds, it helps the final result feel much more complete.
  • Touch, Sound, and Motion Sensing in One Small Board
    This board does more than show information. It also gives your project multiple ways to respond to the user. The touch screen is great for menus and controls. The microphone can be used for recording, sound triggers, or voice interaction. The IMU can detect orientation, shaking, flipping, and motion. With these built in, you can build a small device that can “listen”, “move”, and respond to touch, not just display data.
  • Built for BLE and Battery-Powered Ideas
    Powered by XIAO nRF52840 Plus, this version is a good fit for Bluetooth and battery-powered projects. Use it to build a BLE remote, motion controller, smart badge, wearable notifier, motion-aware device, or a mini Bluetooth terminal that connects to a phone, computer, or gateway. For projects that do not need Wi-Fi but need to stay small and mobile, this version is a better match.
仕様
SpecificationXIAO 1.47'' IPS Touch Display(nRF52840)XIAO 1.14'' IPS Display(nRF52840)XIAO 0.96'' IPS Display(nRF52840)
Product PositioningTouch & Full InteractionSensing & ExpansionUltra-Compact
Core ControllerSeeed Studio XIAO nRF52840 Plus
ProcessorNordic nRF52840, ARM® Cortex®-M4 32-bit processor with FPU, 64 MHz
Memory
256 KB RAM + 1 MB internal Flash + 2 MB onboard Flash
Wireless ConnectivityBLE 5.4
Display Type1.47" IPS TFT LCD1.14" IPS TFT LCD0.96" IPS TFT LCD
Resolution172 × 320135 × 24080 × 160
Display DriverJD9853AST7789ST7789
Display InterfaceSPI
Touch InputCapacitive TouchNoNo
6-Axis IMUYes
PDM Digital MicrophoneYes
MicroSD Card SlotYesNoNo
Grove I2C ConnectorNoYesNo
User Buttons232
Battery Connector2-pin JST 2.0 Connector for 3.7 V LiPo
Battery MonitoringBattery status detection supported; battery voltage can also be monitored for battery-level estimation.
Expansion Interfaces1x I2C Interface
1x I2S Interface
1x SWD Interface
2x User Button Interface
1x I2C Interface
1x I2S Interface
1x SWD Interface
3x User Button Interface
1x I2C Interface
1x I2S Interface
1x SWD Interface
Board Size26.4 × 51.4 × 12.6 mm26 × 48 × 10.6 mm18.8 × 43.6 × 10.6 mm
Best ForTouch UI, portable HMI, local media and data loggingPortable sensor displays, Grove devices, physical controllersSmart badges, tiny wearables, BLE status displays
ハードウェア概要
  • Onboard
用途
  • Smart Badge
  • AI Wearable Prototype
  • BLE Remote Controller
  • Motion-Based Interaction Device
  • Digital Pet and Interactive Toy
認証
HSCODE8517629990
USHSCODE8517620010
UPC
EUHSCODE8517180000
COOCHINA
部品リスト
XIAO 1.47'' IPS Display(nRF52840)×1
SKU 100004242
XIAO 1.47" IPS Touch Display (nRF52840) is a ready-to-use mini smart device development board. It brings a 1.47-inch capacitive display, microphone, IMU, MicroSD card slot, battery connector, and user buttons together with the pre-soldered XIAO nRF52840 Plus. With display, touch, sound, motion sensing, and Bluetooth Low Energy (BLE) built into one compact board, it makes it easier to build portable smart devices without wiring multiple modules.
It is ideal for smart badges, wearable devices, BLE controllers, digital pets, motion-aware gadgets, and portable HMI prototypes.
XIAO Dev Board
Display Size
USD$19.90
product.detail.alsoAdd.title
