おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Here we offer you this high-resolution, ultra-wide viewing angle IPS HDMI display. Specifically, this display has a resolution of 720*1280 and a viewing angle up to double 178 degrees. It is small and light, easy to carry. No need for drivers. We tested it with raspberry pi 3b/3b+ and windows10.
In addition, this display has a backlight-adjustable function that allows you to adjust the brightness using the buttons on the back.
Tip
In order to protect the screen, the screen surface comes with a protective film. If you want to tear off the protective film, you need to use a screwdriver to remove the screws on the outer casing.
This series includes the following three products:
5 inch 720x1280 HDMI IPS LCD Display
7 inch 720x1280 HDMI IPS LCD Display
10.1 inch 1200x1980 HDMI IPS LCD Display
  • Ultra-thin.
  • High viewing angle .
  • High resolution.
Usage
If you are willing to know more information about Raspberry Pi display, please view the table as follow.
Product nameResolutionPower supplyDisplay interfaceFor use withDimension(mm)Touch panel typeDisplay tec.
5 inch 720x1280 HDMI IPS LCD Display720x12805VHDMI2.0Raspberry Pi3, Windows, etc.134x84NoneIPS
5 inch 800x480 Capacitive TouchScreen800x4805VHDMI & USB 2.0Raspberry Pi3, Windows, etc.184x106x45CapacitiveTFT
5 Inch HDMI Display with USB TouchScreen800x4805VHDMI & USB 2.0Raspberry Pi3, Pi4, Windows, etc.170x90x40ResistiveTFT
5 inch Capacitive touch screen & Acrylic Case Kit800x4805VHDMI & USB 2.0Raspberry Pi3, Windows, etc.210x150x50CapacitiveTFT
7 inch 720x1280 HDMI IPS LCD Display720x12805VHDMI2.0Raspberry Pi3, Windows, etc.192x118NoneIPS
Raspberry Pi 7 inch Touchscreen Display800x4805VDisplay ribbon cableRaspberry Pi3, Pi2, Pi194x110x20CapacitiveTFT
7 Inch 1024x600 Capacitive Touch Screen With Camera Kit1024x6005VHDMI & USB 2.0Raspberry Pi3, Windows, etc.177x113x15CapacitiveTFT
10.1 inch 1200x1920 HDMI IPS LCD Display1200x19205VHDMI2.0Raspberry Pi3,Pi4,Windows,etc.255x165NoneIPS
15.6 Inch 1920*1080 Full HD IPS Touch Screen Portable Monitor1920x10805VMini DP/ Mini HDMI / Type CRaspberry Pi3,Pi4,Windows,etc.375x230x12CapacitiveIPS
7 Inch HDMI 1280x800 IPS Display1280x8007.5V~12VAV + VGA + HDMI (HDMI 1.2)Raspberry Pi3, Windows, etc.162x106x5NoneIPS
7 Inch 1024x600 Capacitive Touch Screen DIY Kit1024x6005VAV + VGA + HDMI (HDMI 1.2)Raspberry Pi3, Windows, etc.265x165x50CapacitiveTFT
10.1 Inch LCD Display - 1366x768 HDMI&VGA&NTSC&PAL1366x7685V~24VAV + VGA + HDMI (HDMI 1.2)Raspberry Pi3,Pi4,Windows,etc.230x150x5NoneTFT
Raspberry Pi HDMI LCD (10.1 inch)1280x8005VHDMI & USB 2.0Raspberry Pi3,Pi4,Windows,etc.290x200x35CapacitiveIPS
ドキュメント
認証
HSCODE8528521200
USHSCODE8531200040
UPC841454122371
EUHSCODE8531202090
COOCHINA
認証
Dimension
5 inch
Resolution
720x1280
Refresh Rate
60HZ
Panel Type
IPS panel (viewing angle double 178°)
Power
Micro usb standard interface
Working Current
5v  280mA
Support Platform
Paspberry Pi,Windows,etc. HDMI interface
Interface
HDMI2.0 (Compatible with HDMI1.4)
Frame Material
colorful acrylic plate
HDMI2.0 cable, micro USB cable
Ultra-thin, high viewing angle, high resolution
Other Functions
Backlight power switch, backlight brightness adjustment
SKU 104990442
USD$49.95
廃番
product.detail.alsoAdd.title
