おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Key Features
  • Raspberry Pi RP2040 Microcontroller: The all-new low-cost Raspberry Pi silicon is the first microcontroller developed by the Raspberry Pi Foundation.
  • Dual-Core 32-bit Arm® Cortex®-M0+: Get started with machine learning with TinyML, TensorFlow Lite or Edge Impulse thanks to the high-performance energy-efficient microprocessor clocked at 133 MHz.
  • U-blox® Nina W102: The first and only RP2040 board with native Bluetooth and WiFi connectivity.
  • ST LSM6DSOX 6-axis IMU: Combined accelerometer and gyroscope with a dedicated machine learning core.
  • Microchip ATECC608A Cryptographic Co-processor: The powerful, low-power processor that is used in all MKR Family boards.
  • Step down converter: Achieve high efficiency and low noise over a wide input voltage range with the built-in switch mode power supply
  • Arduino Nano Form Factor: Solder headers to start prototyping with a breadboard, then solder directly into your final product. The familiar Nano form factor gives you the choice to use the board according to your needs, backed by the vibrant Arduino community.
The feature-packed Arduino Nano RP2040 Connect brings the new Raspberry Pi RP2040 microcontroller to the Nano form factor. Make the most of the dual-core 32-bit Arm® Cortex®-M0+ to make the Internet of Things projects with Bluetooth and WiFi connectivity thanks to the U-blox® Nina W102 module. Dive into real-world projects with the onboard accelerometer, gyroscope, RGB LED and microphone. Develop robust embedded AI solutions with minimal effort using the Arduino Nano RP2040 Connect!
Hey community, we've set up a #tinyml channel on our Discord server, please click to join for 24/7/365 making, sharing, discussing and helping each other out.
BoardNameArduino® Nano RP2040 Connect
SKUABX00053
MicrocontrollerRaspberry Pi RP2040
USB connectorMicro USB
PinsBuilt-in LED Pin13
Digital I/O Pins20
Analog input pins8
PWM pins20 (except A6, A7)
External interrupts20 (except A6, A7)
ConnectivityWi-FiNina W102 uBlox module
BluetoothNina W102 uBlox module
Secure elementATECC608A-MAHDA-T Crypto IC
SensorsIMULSM6DSOXTR (6-axis)
MicrophoneMP34DT05
CommunicationUARTYes
I2CYes
SPIYes
PowerCircuit operating voltage3.3V
Input voltage (VIN)5-21V
DC Current per I/O Pin4 mA
Clock speedProcessor133 MHz
MemoryAT25SF128A-MHB-T16MB Flash IC
Nina W102 uBlox module448 KB ROM, 520KB SRAM, 16MB Flash
DimensionsWeight6 g
Width18 mm
Length45 mm
Compatibility
  • Software&Cloud
    • Arduino IDE
    • Arduino CLI
    • IoT Cloud
    • Web Editor
Pinout
認証
HSCODE8517180050
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOItaly
Arduino Nano RP2040 Connect with Headers - U-blox Wifi/6-axis IMU
SKU 102991557
The Arduino Nano RP2040 Connect is the feature-packed Arduino Nano board built with Raspberry Pi's new silicon.It supports WiFi connectivity thanks to the U-blox® Nina W102 module.
JPY¥6015.00
product.detail.alsoAdd.title
