製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Easy to install
  • Provides better heat dissipation through passive cooling using a heat sink
  • Provides faster cooling through active cooling using an adjustable speed control fan
  • Provides a good contact surface between the onboard components and the heat sink with thermal pads
This is an aluminum alloy heat sink that is suitable to use with the Raspberry Pi Compute Module 4. It provides better heat dissipation through passive cooling while protecting the compute module. Also, it provides faster cooling through active cooling using a PWM fan. The speed of the fan can be easily controlled using a Python script provided. It is very easy to install and provides a good contact surface between the onboard components and the heat sink with the use of the included thermal pads.
How to Assemble
  • Paste thermal pads on CM4 module
  • Place heat sink over the CM4 module and secure it with screws and nuts
Note
Please beware of the direction of the screws and nuts
Dimensions
  • 1 x Aluminum Alloy CNC Heat Sink with Fan for Raspberry Pi CM4 Module
  • 1 x Screwdriver
  • 4 x M2.5 Screw
  • 4 x M2.5 Nut
  • 5 x Thermal Pad
ドキュメント
認証
HSCODE8414599060
USHSCODE8473305100
UPC
EUHSCODE8414591500
COOCHINA
Aluminum Alloy CNC Heat Sink with PWM Fan for Raspberry Pi CM4 Module
SKU 114070161
Heat Sink Only
JPY¥2055.00
