Note
A Dual Gigabit Ethernet Carrier Board for Raspberry Pi CM4 is not included with this product.
When you are running the Dual Gigabit Ethernet Carrier Board for long hours, the board tends to get very hot with all the workloads. So, the PC/ABS Case with Aluminum Heatsink is the ultimate solution for your overheating problems.
This PC/ABS case comes with an Aluminum alloy top which has a large heatsink in order to cool down the CM4 at extreme loads. Also, this case provides better protection as well and is suitable to be used in industrial applications. The case has long rubber feet for better stability when placed on a flat surface. You can mount this case in two different methods. One is to use the keyhole slot wall mount and hang it on the wall (you can hang in 2 different orientations). The other is to use the 3 mounting holes and mount onto a DIN rail.
1 x PC/ABS Case with Aluminum Heatsink for Dual Gigabit Ethernet Carrier Board for Raspberry Pi CM4
| HSCODE | 7616999000 |
| USHSCODE | 7612901090 |
| UPC | |
| EUHSCODE | 7616991091 |
| COO | CHINA |
