おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Arduino Breakout for LinkIt Smart 7688 Duo is an Arduino Yún compatible (share the same MCU model) and a Grove port feature expansion board for LinkItTM Smart 7688 Duo development platform. This breakout board allows you to use different features from Arduino Yún and LinkIt Smart 7688 Duo which will help you build rich applications based on various, robust and compiled Arduino sketches. This breakout board will save a lot of work and makes prototyping easier through simplified wiring. So it helps a beginner get a quick start. It supports serial buses like I2C, UART and provides access to reserved original pins of LinkItTM Smart 7688 Duo. It also comes with USB and Ethernet ports.
In addition, it also integrates several frequently used peripheral ports such as USB port, Ethernet port. LinkIt Smart 7688 Duo(a compact controller board) is an open development board, based on the OpenWrt Linux distribution, MT7688 and ATmega32u4. The board is designed especially to enable the prototyping of Rich Application IoT devices for smart house.
  • Arduino Shield Compatible,
  • 1 x Ethernet to connect to internet
  • 1 x USB 2.0 for more peripherals
  • Grove interfaces: I2C × 2, Analog × 3, Digital× 6, UART × 1
  • 4-pin debug port × 1, ICSP × 1
Application Ideas
  • IoT/Gateway Device.
  • Robotics
  • Smart multimedia devices
  • Teaching and learning
認証
HSCODE8543909000
USHSCODE8543903500
UPC841454118404
EUHSCODE8543709099
COOCHINA
技術詳細
Dimensions111mm x53mm x18mm
WeightG.W 83g
BatteryExclude
Input voltage5.0V(With USB Power port)
Operating voltage3.3V
Debug port4-pin debug port × 1
Grove interfacesI2C × 2, Analog × 3, Digital× 6, UART × 1
Ethernet PortYes
USB PortUSB Type-A
ICSP PortYes
部品リスト
Arduino Breakout for LinkIt Smart 7688 Duo1
SKU 103030033
Conpatible with other Arduino shields 1 x Ethernet port for internet connection 1 x USB 2.0 for more peripherals Provide up to Grove interfaces 4-pin debug port × 1, ICSP × 1
USD$12.95
廃番
product.detail.alsoAdd.title
