This is a thin and lightweight heat sink, equipped with a 3510 ultra-quiet cooling fan, that is suitable to use with the Raspberry Pi 4. It provides better heat dissipation through passive cooling while protecting the Raspberry Pi. Also, it provides faster cooling through active cooling using a PWM fan. The speed of the fan can be easily controlled using a Python script provided, which is perfectly compatible with Raspberry Pi OS. Other systems need to manually write Python or C code to drive the fan speed through PWM. It is very easy to install and provides a good contact surface between the onboard components and the heat sink with the use of the included thermal pads.
Note
Automatic speed control function is only supported by Raspberry Pi OS
Note
Please beware of the direction of the screws and nuts
