BeagleV® - Fire is a compact and powerful device that is designed to meet your computing needs with its impressive features and specifications. Powered by Microchip's PolarFire® MPFS025T FCVG484E 5x core RISC-V SoC with FPGA fabric, it is operating at up to 667 MHz. It ensures power-efficient and highly flexible operation and instruction with low-power FPGA fabric.
It is equipped with onboard 2GB LPDDR4 and Kingston 16GB eMMC. In addition to the internal storage, the device offers a microSD card slot, allowing you to expand the storage capacity as per your needs.
Featuring a Gigabit Ethernet interface, an integrated Host / Device / Power Supply function in one USB 2.0 Type-C port, and one SYZYGY High-speed connector, this board allows expanded connectivity options with compatible modules.
Coming with rich extensions, this development board provides the CSI connector with 22 pins and provides support for a 4-lane camera. It also supports a Wi-Fi module through the M.2 Key E slot to enable wireless connection. With the standard 2*46 pins BeagleBone® Header, the device offers GPIO pins for connecting external devices. Additionally, it includes a 6-pin UART debug connector and a 10-pin JTAG port for debugging purposes.
BeagleV® - Fire | BeagleV® - Ahead | |
Processor | Microchip's PolarFire® MPFS025T FCVG484E ( 5x core RISC-V SoC with FPGA fabric) | T-Head TH1520 (quad-core Xuantie C910 processor) |
USB Port | 1* USB 2.0 TypeC ( Host / Device / Power) | 1* USB3.0 Micro-B OTG |
Multimedia | 1*CSI | 2*CSI,1*DSI, 1*HDMI |
Other Connector | 1* M.2 Key E, support 2.4GHz/5GHz WiFi module 1* SYZYGY High speed connector | 1* MikroBus |
Parameters | Description |
Processor | Microchip's PolarFire® MPFS025T FCVG484E |
5x core RISC-V SoC with FPGA fabric: 4x Application core, 1x monitor/boot core | |
Memory | 2GB, LPDDR4 |
Storage | Kingston 16GB eMMC |
Wireless | 1 x M.2 Key E, support 2.4GHz/5GHz WiFi module |
LAN | 1 x Gigabit Ethernet |
USB Port | Connectivity: Host / Device Power Input: 5V |
SD Card | 1 x microSD card slot |
CSI | 1 x CSI connector (22 pins), support 4 lanes Camera |
LEDs | 12 x User LEDs |
1 x Power LED | |
Buttons | 1 x User button |
1 x Reset button | |
Power | 5V Screw terminal / USB C |
GPIO | 2*46 pins BeagleBone® Header |
Debug | 6 pins UART debug connector |
10 pins JTAG port | |
Cerfication | CE,FCC, RoHS, REACH |
Other Connectors | 1 x SYZYGY High speed connector, designed for:
Working Temperature | 0°C~70°C |
Board Dimension | 86.38*54.61*18.8mm |
Gross Weight | 106g |
Net Weight | 45.8g |
BeagleV®-Fire Boards | x1 |
Quick start card | x1 |
BeagleV® - Fire is an open-source RISC-V Single Board Computer coming with low-power FPGA fabric, designed for highly flexible custom scenarios. It offers 2GB memory and 16GB eMMC, along with versatile connectivity and rich extensions, perfect for various personal and professional applications.
