製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Make sure to get the maximum amount of flight-time from your Crazyflie 2.1/2.0 using this spare battery and charger.
  • 240mAh LiPo battery
    • Weight: 7.1g
    • Size (WxHxD): 20x7x30mm (not including cable)
    • Capacity: 240mAh
    • Nominal voltage: 3.7 V (1 Cell)
    • Discharge: 15C
    • Charge: 2C
    • Operating Temperature: 0 ~35°C (Charging) / -20~60°C (Discharging)
    • Connector: Molex 51005-2P (Pin 1 positive)
    • Features
    • Electrical specification
    • Mechanical specification
  • LiPo battery charger
    • Weight: 1.2g
    • Size (WxHxD): 10.5x16x1.6mm (not including cable)
    • Connector for the Crazyflie 2.0 stock battery
    • Max charging current: 500mA
    • Supply voltage: 5V
    • μUSB charging connector
    • Based on the MCP73832 single-cell Li-Po charger
    • Connection points allows chaining of multiple chargers (1x2, 2.54mm pitch)
    • 500mA single-cell Li-Po battery charger
    • Charging indicator
    • Connection points for chaining of multiple chargers
    • Features
Caution
Using the battery under direct sunlight may cause overheating, which could result in invalidation or fire. The battery should be charged with proper charger, in compliance with correct operation instruction.
  • Bitcraze
  • For more details, please visit Wiki.
  • For technical discussion, please visit Forum.
  • For projects that you would like to share with the community, please visit Recipe.
Tech Support
If you have any further question for technical support, please contact [email protected]
ドキュメント
認証
HSCODE8504909090
USHSCODE8504904100
EUHSCODE8543709099
COOCHINA
技術詳細
Dimensions0mm x0mm x0mm
WeightG.W 11g
BatteryLithium Cells / Batteries loose (bulk) UN3480-PI965
部品リスト
LiPo battery charger1
240mAh LiPo battery1
Crazyflie 2.1/2.0 spare battery (including charger)
SKU 110060403
240mAh LiPo battery including 500mA USB charger for Crazyflie 2.1, Crazyflie 2.0.
JPY¥1583.00
