製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
This product has shipping restrictions for certain countries. It cannot be shipped to the following regions: China
  • Easy to assemble: no soldering required
  • Automatic Expansion Deck Detection
  • Cross-Platform Compatibility: Compatible with iOS and Android via Bluetooth LE, and with Windows, Mac, and Linux using Crazyradio, Crazyradio PA, or Crazyradio 2.0 for flying.
  • Long-Range Radio Communication: Tested to further than 1 km radio range line-of-sight (LOS) with the Crazyradio PA
  • Wireless firmware updates
  • Dual-MCU architecture: Supports Real-time logging, graphing and variable setting in addition to full use of expansion decks when using a Crazyradio or Crazyradio PA and a computer
The Crazyflie 2.1+ of the successful Crazyflie 2.X development platform comes with upgraded battery and propellers for a up to 15% improved flight performance. Together with an extensive ecosystem of software and deck expansions it’s ideal for education, research and swarming.
Crazyfly 2.1 + is designed to be as flexible as possible. This meant adding as many features as users could fit and writing firmware made to be modified. In addition to the default functionality that comes with the Crazyflie 2.1 + that added a flexible expansion interface where a variety of expansion decks can be attached, both on the top and the bottom of the Crazyflie 2.1 +. From this expansion interface the user can access buses such as UART, I2C and SPI as well as PWM, analog in/out and GPIO.
Go to Getting started with the Crazyflie 2.1 + to build your crazyflie, update its firmware and fly with it with the clients. Also take a look at our System overview to learn more about Crazyflie’s ecosystem of positioning systems, Clients and of course the crazyflie itself with its expansion decks.
仕様
Parameter
Microcontrollers Spec
Main application MCU
STM32F405,Cortex-M4, 168MHz, 192kb SRAM, 1Mb flash
Radio and power management MCU
nRF51822,Cortex-M0, 32Mhz, 16kb SRAM, 128kb flash
Connector
micro-USB
On-board LiPo charger
100mA, 500mA and 980mA modes available
Memory
8KB EEPROM
Port
Full speed USB device
Partial USB OTG capability present but no 5V output
IMU Spec
3 axis accelerometer / gyroscope
BMI088
High precision pressure sensor
BMP388
Flight Spec
Flight time with stock battery
7 minutes
Charging time with stock battery
40 minutes
Max recommended payload weight
15 g
Radio Spec
ISM band radio
2.4GHz
radio range LOS
> 1 km (Increased range with 20 dBm radio amplifier)
Wireless
BLE
Support platform
iOS / Android clients
Win/Linux/OSX python client(Any gamepad/controller with at least 4 analog axes)
Antenna
Dual antenna support
Onboard components
chip antenna
U.FL connector
Expansion connector mode
VCC
3.0V (max 100mA)
VCOM
max 1A(unregulated VBAT or VUSB)
VUSB
both for input and output
Interfaces
SPI
I2C (400kHz)
2 x UART
4 x GPIO/CS for SPI
1-wire bus for expansion identification
2 x GPIO connected to nRF51
Mechanical Spec
Takeoff weight
27g
Size (WxHxD)
92x92x29mmm (motor-to-motor and including motor mount feet)
ハードウェア概要
Note
  • The Crazyflie 2.1+ is a 3.0V system, meaning a high output will be 3.0V but still compatible with a 3.3V system,
  • All IO pins are 5V tolerant except PA5 and the NRF51 pins,
  • The NRF51 pins can be multiplexed with any of the available NRF51 peripheral,
  • The STM32F405RG pins can be multiplexed.
用途
● Use the Crazyflie 2.X for development
The Crazyradio PA enables you to connect the Crazyflie 2.X to a computer wireless and download new firmware, modified to your liking. The logging and parameter frameworks provide APIs for getting and setting data in the Crazyflie 2.X live, even when you are flying! All software, firmware, as well as clients on the computer that is open source and the source code is available for you to play with as you like.
● Paint in the dark with a Crazyflie
The Crazyflie 2.X is fun to fly as is but adding the LED-ring deck and flying in the dark adds a new dimension. The RGB LEDs let you choose any colour and with some coding any light sequence can be displayed, for instance, controlled by the on board sensors. Why not take photos with an open shutter of a moving Crayflie 2.X and paint in the dark?
● assistance when flying the Crazyflie and Crazyradio PA
Flying a quadcopter like the Crazyflie manually requires some skill and practising. By adding the Flow deck v2 the Crazyflie gets more information about its motion and can assist the pilot.
note: Currently assisted mode is only supported when flying using a computer and gamepad, not with a mobile device.
● awareness of the surroundings to the Crazyflie and Crazyradio PA
The Multi-ranger deck measures the distance to objects forward/back/left/right and up. It can be used for obstacle avoidance, mapping a room or games where the Crazyflie 2.X “bounces” between the walls of a room. Combine with a Flow deck v2 to measure the distance to the floor as well and support autonomous flight.
認証
HSCODE9023009000
USHSCODE9023000000
UPC
EUHSCODE9023001000
COOCHINA
部品リスト
Crazyflie 2.1 Plus control board
1
250mAh LiPo battery(spare part)
1
7mm DC coreless motor (1 spare)(spare part)
5
7mm motor mounts (2 spare) (spare part)
6
Foam battery pad
1
CCW propellers (3 spare) (spare part)
5
5
Battery holder deck (spare part)
1
Short male deck connectors(spare part)
2
Long male deck connectors (spare part)
2
micro-USB cable (48cm) (spare part)
1
Crazyflie 2.1+ version - Open Source Mirco Quadcopter Drone,Support Bluetooth5 LE,Robotics,Suitable for Indoor/Small Space/High Density
SKU 114993295
The Crazyflie 2.1+ version is a versatile open-source flying development platform that only weighs 27g and fits in the palm of your hand. Crazyflie 2.1 is equipped with a low-latency/long-range radio as well as Bluetooth LE. This gives you the option of downloading our app and using your mobile device as a controller or, in combination with the Crazyradio PA, using your computer to display data and fly with a game controller.This product is a co-create collaboration with Seeed Studio and Bitcraze.
JPY¥37986.00
