おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Suitable to use with Raspberry Pi 4
  • PC/ABS case with better protection which is suitable for industrial applications
  • Case with long rubber feet for better stability when placed on a flat surface
  • Keyhole slot wall mount with the ability to hang in two orientations
  • DIN rail mount support with 3 mounting holes
  • Three Aluminum and one Copper heat sink included to cool down the components
This is a PC/ABS case which is suitable to use with a Raspberry Pi 4. It provides better protection as well and is suitable to be used in industrial applications. Also, this includes a heat sink kit with 3 Aluminum and 1 Copper heat sinks, so that they can be used to cool down the components on the Raspberry Pi 4 when it is running with heavy load.
The case has long rubber feet for better stability when placed on a flat surface. You can mount this case in two different methods. One is to use the keyhole slot wall mount and hang it on the wall (you can hang in 2 different orientations). The other is to use the 3 mounting holes and mount onto a DIN rail.
Wall Mount (horizontal and vertical orientations)
DIN Rail Mount
  • 1 x PC/ABS Case with Aluminum Heatsink for Dual Gigabit Ethernet Carrier Board for Raspberry Pi CM4
  • 3 x Aluminum heat sinks
  • 1 x Copper heat sink
認証
HSCODE8414599060
USHSCODE7612901090
UPC
EUHSCODE8414591500
COOCHINA
Desktop Raspberry Pi 4 Case with Heat Sinks Kit
SKU 110070088
USD$9.90
product.detail.alsoAdd.title
