製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • 1mm Ultra-Flexible & 360° Cool White:Crafted from Flexible FPC and Silicone Phosphor, this 1mm filament delivers a 360° full-angle glow. It emits a crisp 6500K Cool White light with CRI >80, providing accurate color rendering and a continuous linear aesthetic—far superior to traditional rigid LEDs.
  • 110mm Double-Ended Design: Featuring conductive pads on both ends, this design ensures consistent voltage distribution for uniform brightness across the entire 110mm length. It supports versatile mounting configurations like suspension or tension mounting, making it ideal for creating large-scale contours or "liquid light" effects.
  • 3V 300mA Spec & Driver Compatibility: Operating at 3V with a high current draw (~300mA), this extra-long filament delivers intense brightness. It is specifically optimized for the High-Power Ports of the COB LED Driver Board for Seeed Studio XIAO, ensuring stable and sufficient drive current for high-load applications.
  • DIY Connection Kit Included:Prepared for medium-to-large projects, the pack includes 5 pieces of 110mm strips and 10 pre-tinned red/black electronic wires (10cm). Designed for makers, users can solder the connections themselves, enjoying the flexibility to build custom light paths from scratch.
仕様
Parameter
Length
~110 mm
Width
~1.0 mm
Color Temperature
6500K (Cool White)
Luminous Flux (Brightness)
21-25 lm (@ 300mA)
Operating Voltage
3V (Current Limiting Required)
Operating Current
<300mA (Recommended)
Power Consumption
~0.8W
Beam Angle
360°
CRI
>80
Material
Flexible FPC + Silicone Phosphor
Connector Type
Double Ended
Operating Temp
-30°C ~ +55°C
用途
  • 3D Print Lighting: Embed inside models for cool glowing effects.
  • Christmas & Holiday Decor: Add festive glow to tree ornaments, wreaths, or gift boxes.
  • Mini Neon Signs: Bend into shapes for unique desktop decor.
  • Model Detailing: Upgrade robots and figures with precision lighting details.
認証
HSCODE9405429000
USHSCODE8541410000
UPC
EUHSCODE9405413910
COOCHINA
部品リスト
Double Ended COB LED Strip - White(6500K) 130mm
×5
100mm Red Connecting Wire
x5
100mm Black Connecting Wire
x5
Double Ended COB LED Strip - White(6500K) 130mm(5PCS)
SKU 100074846
This pack contains 5 pieces of 1mm Ultra-Thin Double-Ended COB Filaments (110mm). The double-ended power design ensures consistent high-intensity brightness across long spans. Ultra-flexible and uniform, these strips bend 360° to trace complex shapes—delivering smooth, continuous light for bold contours and creative installations. Each strip comes with DIY connecting wires (Total 10 wires).
Connection Type
Length
Package
JPY¥871.00
