Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • 1mm Ultra-Flexible & 360° Cool White:Crafted from Flexible FPC and Silicone Phosphor, this 38mm filament packs high-density chips into a tiny form factor. It emits a crisp 6500K Cool White light with CRI >80, providing a smooth, dot-free.
  • 38mm Double-Ended Design: With conductive pads on both ends, this short-span design allows for stable suspension or tension mounting. The 1mm invisible width enables it to bridge narrow gaps in models or be embedded into acrylics, creating "floating" light effects without bulky wiring.
  • 3V 100mA Spec & Driver Compatibility: Operating at 3V with a high current draw (~100mA), this extra-long filament delivers intense brightness. It is specifically optimized for the Low-Power Ports of the COB LED Driver Board for Seeed Studio XIAO, ensuring stable and supporting dynamic breathing or blinking effects.
  • DIY Connection Kit Included:A high-volume kit containing 10 pieces of 38mm strips and 20 pre-tinned red/black electronic wires (10cm). Designed for makers, users can solder the connections themselves, enjoying the flexibility to build custom light paths from scratch.
Parameter
Length
~38 mm
Width
~1.0 mm
Color Temperature
6500K (Cool White)
Luminous Flux (Brightness)
>20 lm (@ 100mA)
Operating Voltage
2.7-3.2V (Current Limiting Required)
Operating Current
<100mA (Recommended)
Power Consumption
~0.8W
Beam Angle
360°
CRI
>80
Material
Flexible FPC + Silicone Phosphor
Connector Type
Double Ended
Operating Temp
-30°C ~ +55°C
Application
  • 3D Print Lighting: Embed inside models for cool glowing effects.
  • Christmas & Holiday Decor: Add festive glow to tree ornaments, wreaths, or gift boxes.
  • Mini Neon Signs: Bend into shapes for unique desktop decor.
  • Model Detailing: Upgrade robots and figures with precision lighting details.
Certification
HSCODE9405429000
USHSCODE8541410000
UPC
EUHSCODE9405413910
COOCHINA
Double Ended COB LED Strip - White(6500K) 38mm
×10
100mm Red Connecting Wire
x10
100mm Black Connecting Wire
x10
Double Ended COB LED Strip - White(6500K) 38mm(10PCS)
SKU 100052952
This pack contains 10 pieces of 1mm Ultra-Thin Double-Ended COB Filaments (38mm). The double-ended power design ensures consistent high-intensity brightness across long spans. Ultra-flexible and uniform, these strips bend 360° to trace complex shapes—delivering smooth, continuous light for bold contours and creative installations. Each strip comes with DIY connecting wires (Total 10 wires).
Connection Type
Length
Package
JPY¥871.00
