おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
This product is a DIY kit. Assembly and soldering are required to complete the ESP-FLY drone. The product images showing the fully assembled unit are for demonstration and reference purposes only, showcasing the final result you can achieve after assembly.
  • Ultra-Compact & Lightweight Design: With a compact footprint of 67mm x 67mm x 31mm and a take-off weight of only 25g (including battery), the ESP-FLY is incredibly agile and safe for indoor flight exploration.
  • Powerful Brain with XIAO ESP32-S3: Driven by the XIAO ESP32-S3 module, featuring a dual-core 240MHz CPU and 2.4GHz Wi-Fi, acting as a high-performance, ultra-compact flight controller.
  • Dual Control Methods: Fly seamlessly from your phone via the ESP-Drone app (Wi-Fi AP mode) with low latency (~7-25 ms), or use a radio controller via ESP-NOW for extended range and stick precision.
  • Stable Flight & Custom PCB: Features a custom 4-layer flight controller PCB integrating an MPU-6050 6-axis IMU for self-leveling stability in Angle mode, paired with high-speed coreless motors.
  • Perfect for STEM & DIY Learning: A hands-on kit that requires basic soldering and assembly, making it an ideal platform for students and makers to learn drone technology and firmware customization.
仕様
CategoryFeatureSpecification
CoreMicrocontrollerSeeed Studio XIAO ESP32-S3
ProcessorXtensa® 32-bit LX7 dual-core,
up to 240MHz
Flight SystemIMU SensorMPU6050
Propulsion615 Coreless Motors (70,000 RPM)
Propellers30mm (CW & CCW)
ConnectivityWireless2.4 GHz Wi-Fi (AP mode) & ESP-NOW
Control Range~50m (via smartphone) / ~200m (ESP-NOW via controller)
PowerBattery3.7V 250mAh 25C LiPo Battery
Flight Time~5 minutes
ChargingUSB-C (via XIAO)
MechanicalTake-off Weight25g (including battery)
Dimensions67m x 67mm x 31mm
ハードウェア概要
用途
  • STEM Education
  • Hobbyist DIY Projects
  • Indoor Flight Practice
認証
HSCODE8543709990
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
部品リスト
Seeed Studio XIAO ESP32-S3×1
2.4G Antenna for XIAO ESP32-S3×1
IMU/Motor Driver Module×1
24AWG Red/Black Wire -
For joining battery power to XIAO
×2
Coreless Motor (6×15 mm)×4 (2 CW and 2 CCW motors
with pre-attached wires)
Propeller (30 mm tri-blade)×8 (4 CW and 4 CCW props)
1S LiPo Battery (3.7V, 250 mAh)x1
3D printed Parts Set - Frame,
standard Top Cover,
and optional FPV Top Cover
x1
"ESP-FLY" Stickerx1
Battery-mounting Zip-Tiex1
Landing Gear Enameled Solid Wirex4
ESP-FLY DIY Kit - DIY Micro Drone Kit based on XIAO ESP32-S3 by Max Imagination
SKU 114993694
The ESP-FLY is a compact, lightweight DIY micro drone kit powered by the Seeed Studio XIAO ESP32-S3. This product is a Co-Create collaboration with Seeed Studio and Max Imagination. Designed for STEM education and hobbyists, it offers dual control methods via Wi-Fi (mobile app) or ESP-NOW (radio controller), providing a fun, hands-on way to understand electronics and aerial robotics.
USD$59.99
product.detail.alsoAdd.title
