おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
❗Important Notice: USB Programming/Debug Function Availability
Please note that the USB Programming/Debug function is only available on the latest version of the EdgeBox-ESP-100. The previous version of the device only supports power supply through the USB-A port and does not support programming/debugging.
⚠️ Do Not Connect the USB-A Port of Older Versions to a PC USB Port
Connecting the USB-A port of the old version to a PC may result in improper behavior. Please use only the new version if you intend to use the USB port for programming or debugging purposes.
How to Identify the New Version
The easiest way to distinguish between the old and new versions is by checking the SN (Serial Number) label on the device enclosure.
Old Version SNs:
All serial numbers with 2437 or earlier (e.g 102991735243700001, 102991735243700093)
2437 indicates production in Week 37 of 2024
New Version SNs:
All serial numbers with 2438 or later (e.g 102991735243800001, 102991735243800093)
2438 indicates production from Week 38 of 2024 onwards
  • Multi-Fieldbus Support: CAN, RS485, Ethernet
  • Multi-wireless Capability: On-chip Wifi, BLE connectivity; built-in Cellular 4G LTE module
  • Reliable Hardware Design: Rugged, maintenance-reduced structure
  • Reliable Electrical Design: High isolation, High surge, and short circuit protection
  • IEC 61131-3 compliant programs support (under development)
  • Programmable with ESP-IDF
仕様
Parameters
Detail
Basic
CPU
ESP32S3
Memory
512KB + 8MB RAM
Storage
16MB Flash
Wireless
WiFi
on-chip 2.4 GHz
Bluetooth
on-chip Bluetooth 5.0, BLE
Cellular
4G - A7670G SIMCom LTE Cat 1 module
LoRa®
Supported*
Interface
Ethernet
100M RJ45 *1
USB
USB2.0 A*1
CAN BUS
CAN BUS *1 (Isolated)
RS Serial
RS485 *1 (Isolated)
Digital Input
4 (Isolated) onboard
DC input Voltage - 24V
Digital Output
6 (isolated)
Recommended Voltage - 24V
Analog Input
4 (Isolated)
Input: 0 ~ 20 mA default, 0-10V optional
Analog Output
2 (Isolated)
Output: 0 ~ 5 V
Power Supply
10.8 ~ 36 V
Extra features
RTC
RTC
Encryption Chip
Atecc608a(optional)
Operation temperature
-20 to +60 °C
Certification
RoHS, CE, FCC, UKCA
Warranty
2 Years
The maximum operating voltage is 60V.
用途
  • SCADA
  • Industrial Controller
  • Proportional, Integral, and Derivative (PID) control loops;
  • Logic Sequencing Control
  • Industrial Gateway
認証
HSCODE8471419000
USHSCODE8517180050
UPC841454123569
EUHSCODE8471707000
COOCHINA
部品リスト
EdgeBox-ESP-100
x1
The LoRa® Mark is a trademark of Semtech Corporation or its subsidiaries. LoRaWAN® is a mark used under license from the LoRa Alliance®.
EdgeBox-ESP-100-Industrial Edge Controller, WiFi, BLE, 4G LTE, DIO, AIO, Ethernet, CAN, RS485
SKU 102991735
EdgeBox-ESP-100 represents the lightweight, multi-functional controller. It carries various wireless capabilities and multiple Fieldbus, which makes it an independent PLC for field automation applications, or enables it as an industrial gateway for offering the original PLC the communicated ability to network and cloud.
Raspberry Pi CM4-powered edge IoT gateway with 3*RS485, dual ethernet, and optional wireless connectivity (4G, LoRa®, Wi-Fi/BLE, Zigbee), priced starts from $209.
JPY¥24216.00
product.detail.alsoAdd.title
