OpenClaw OpenClaw
⌘ K
Loading...
External Antenna 868-915MHZ-2dBi;SMA-L195mm-Foldable
Gain at 2dBi for E5 certification, designed for a frequency range of 868MHz to 915MHz, with a collapsible SMA connector for flexible installation.
¥393.00
In stock
  • 10+: ¥393.00
Products
902-928MHz 3dBi Fiberglass Antenna 360mm
902-928MHz 5.8dBi Fiberglass Antenna 800mm
900-930MHz 7dBi Fiberglass Antenna 920mm
902-928MHz 8dBi Fiberglass Antenna 1300mm
868-915MHz 2dBi Foldable Antenna 195mm
868MHz 2.8dBi Long Range Antenna 195mm
915MHz 2.6dBi Long Range Antenna 195mm
860-930MHz 3dBi Indoor Antenna Kit 295mm
Wio-WM1302 LoRa Antenna Kit
2.4/5GHz RP-SMA Wi-Fi Antenna 130mm
RP-SMA Male to N Female RF Cable 300mm
SMA to I-PEX Antenna Cable 120mm
N Female to RP-SMA Male CFD400 Cable 1m
N Female to RP-SMA Male CFD400 Cable 3m
N Female to RP-SMA Male CFD400 Cable 5m
N Female to RP-SMA Male Magnetic Antenna Base 2m
Product Type
Outdoor Fiberglass Antenna
Device-Mount LoRa Antenna
Wi-Fi Antenna
RF Cable & Base
Product Details
Wiki & Learn
Reviews
