Note:
This cable is designed for UART communication only.
Do not use it for I2C devices, as it will swap SCL and SDA lines.
Parameter | Description |
Interface | Grove 4-Pin Buckled Connector (HY2.0-4P) |
Length | 200mm ± 10mm |
Pinout Definition | End A: 1-GND, 2-VCC, 3-White, 4-Yellow End B: 1-GND, 2-VCC, 3-Yellow, 4-White (Crossed) |
Wire Material | PVC insulation, Copper core |
Rated Voltage | 300V |
Package | 5 PCs /Pack |
| HSCODE | 8544422900 |
| USHSCODE | 8544421000 |
| UPC | |
| EUHSCODE | 8544119000 |
| COO | CHINA |
Grove - UART Crossover Cable 4Pin 20cm (5PCs Pack) | ×1 |
This is the essential link for multi-board communication. This specialized Grove cable features internally crossed TX/RX lines, enabling seamless UART connection between two microcontrollers (like dual XIAO ESP32-S3 setups) without breadboards or soldering.
