製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
The Grove-125KHz RFID Reader is a module used to read EM4100 RFID card information with two output formats: Uart and Wiegand. It has a sensitivity with maximum 7cm sensing distance.
  • Selectable output format: Uart or Wiegand.
  • 4Pins Electronic Brick Interface
  • High Sensitivity
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
認証
HSCODE8517709000
USHSCODE8517620090
UPC841454108924
EUHSCODE8517180000
COOCHINA
技術詳細
Dimensions44mm x24mm x9.6mm
WeightG.W 15g
BatteryExclude
Voltage4.75-5.25V
Working Frequency125 KHz
Sensing Distance(Max)70mm
TTL Output9600 baudrate, 8 data bits, 1 stop bit, and no verify bit
Wiegand Output26 bits Wiegand format, 1 even verify bit, 24 data bits, and 1 odd verify bit
部品リスト
Grove - 125KHz RFID Reader1
SKU 113020002
7cm sensing distance 125kHz RFID Card Read Only Arduino Library
JPY¥1898.00
