Grove - 8 Channel I2C Multiplexer/I2C Hub is based on TCA9548A I2C Multiplexer Chip, you can plug up to 8 same-address I2C devices to the same Grove I2C system.
We've already released the Grove - I2C Hub (4 Port) and the Grove - I2C Hub (6 Port). Wait, still not enough? Well well, we know you are seeking more. Here you are, we present you the Grove - 8 Channel I2C Hub.
More importantly, this is more than just a superposition of port quantities. As we all know, I2C devices must use different addresses in the same bus system, even use the Grove I2C Hub (4 or 6 port), the rule is still the rule. However, with the help of Grove - 8 Channel I2C Hub, you can plug up to 8 same-address I2C devices to the same Grove I2C system. All thanks to the TCA9548A I2C Multiplexer Chip. It adopts time-division multiplexing technology so that the same controller can control 8 I2C devices with the same address. No more worrying about address conflicts.
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfill various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
Grove - 8 Channel I2C Hub (TCA9548A |
X1 |
Grove Cable |
X1 |
