製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Grove AC Voltage Sensor is perfect for measuring RMS AC voltages for accurate DIY energy meters. It has adjustable gain for different voltage inputs(120V-240V AC) and it supports a 5 - 3.3v DC power supply
  • High adaptability: It has gained for different voltage inputs (120V-240V AC)
  • High compatibility: Using Analog as output, it can be compatible with many different development boards
  • Accurately measure the voltage changes generated by high power loads when they are turned on
  • Powerful IC: Equipped with MCP6002 core with Analog output
  • Easy to Use: Just sample plug and play which allows you to easily add wireless capabilities.
Smart home has been long regarded as eco-friendly and energy-efficient by applying IoT technology. A simple energy efficiency definition is using less energy or fewer resources to complete the same task (UN’s Sustainable Goal 12: Sustainable Consumption and Production). You might be still wondering why you need an RMS AC voltage sensor for smart and sustainable home applications. The RMS AC voltage sensor allows you to monitor different voltage inputs and visualize the current-voltage status of your appliances.
For example, you can reduce power consumption by adjusting the voltage of a high-voltage appliance at home. Since we don't know what the threshold of the right voltage is, an RMS AC voltage sensor which helps you visualize the current-voltage status of the appliance.
This Grove Voltage Sensor is perfect for measuring RMS AC voltages for accurate DIY energy meters. It features adjustable gain for different voltage inputs (120V-240V AC), the fact that this sensor output is analog lets you integrate it with many different development boards, letting you decide on the sampling frequency, and ADC resolution without limitations. It’s accurate enough to measure the variations in voltage that high-power loads generate when they are turned on, making it a great choice for creating smart energy meters.
Here we are introducing this AC voltage sensor and its story! Christopher Mendez is a Dominican Electronics Engineer, since his beginnings, he has applied his skills to developing IoT solutions, smart homes devices, energy metering, and more, he considers that electrical energy is crucial in our lives, and it is very important to know how we use it in order to be aware of how to do it prudently. This is why he decided to create this Grove compatible Voltage Sensor, to approach people in the energy metering field.
The AC Voltage Sensor has been licensed to Seeed to manufacture and sell. Christopher Mendez will provide the tech support and Seeed will fulfill the order with hardware quality guaranteed. If you are interested in Seeed Licensed Products Program, pls click here to find out more.
If you need tech support you can contact Christopher with email [email protected]
Parameter
Range/Value
Input Voltage
5-3.3V
Output type
Analog
Module IC
MCP6002 (OPAMP)
Application
  • AC Voltage Meter.
  • Smart Energy Monitoring.
  • Machine Learning.
  • Loads Identification.
  • Home automation.
  • IoT projects.
Hardware Overview
Parts List
X1
1. What is Grove?
The Grove system consists of open-source, plug-and-play hardware for modular electronics project building. The system helps accelerate electronics project building by doing away with jumper wires and breadboards so engineers can focus on developing solutions and coding. Currently, Seeed Studio has developed over 400 Grove modules ranging from sensors, LEDs, inputs, wireless, displays, actuators, breakouts, kits, and accessories, making the Grove ecosystem one of the most successful hardware development platforms.
2. What Is Seeed Fusion Licensed Products Program?
Seeed licensing means that the licensor (cooperative partner) grants its own products (software or hardware), trademarks, brands, etc. to the licensee (Seeed) in the form of a contract. Seeed will assist with all electronics manufacturing including structural parts, testing, certification, provide engineering and quality assurance services, and promotion, sales and distribution around the world using Seeed’s own network and channels. Seeed will ensure that your product is well looked after from start to finish.
認証
HSCODE9030899090
USHSCODE9030333800
UPC
EUHSCODE8473302000
COOCHINA
Grove - AC Voltage Sensor (MCP6002)
SKU 101991032
Grove AC Voltage Sensor is perfect for measuring RMS AC voltages for accurate DIY energy meters. It has adjustable gain for different voltage inputs(120V-240V AC) and it supports 5 - 3.3v DC power supply
JPY¥713.00
