おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Grove - BMP280 I2C and SPI Barometric and Temperature Sensor is built around Bosch BMP280. It is a low-cost and high-precision environmental sensor that measures the temperature and barometer. Grove - BMP280 supports both I2C and SPI communication and we provide the BMP280 Arduino library.
  • High accuracy: the absolute accuracy of ±1.0 hPa for pressure measurement and ±1 accuracy for temperature measurement
  • Wide measurement range: Air pressure was measured from 300hpa to 1100hPa
  • As altimeter: It can be used as an altimeter with the accuracy of ±1 meter
  • Dual communication interface: Supports both I2C and SPI communication
  • Grove compatible interface: The product ensures "Plug and Play" and could be versatile for various applications of Grove
The Grove BMP280 Barometer Sensor is built around Bosch BMP280, it is a low-cost and high-precision environmental sensor that measures the temperature and barometer. This sensor supports both I2C and SPI communication and we provide the BMP280 Arduino library.
Grove BMP280 provides precise measurements of barometric pressure and temperature in the environment. The air pressure can be measured in a range from 300 hPa to 1100hPa with ±1.0 hPa absolute accuracy. As for the temperature, the sensor works perfectly for temperatures between - 40℃ and 85℃ with an accuracy of ±1℃.
Owing to its high accuracy on measuring the pressure, and the pressure changes with altitude, we can calculate the altitude with ±1 meter accuracy, which makes it a precise altimeter as well. Another great thing about this module is that you don’t even need to worry about the I2C collisions as it provides both I2C and SPI interfaces. To use SPI, simply de-solder the bonding pads on the back. If you go with I2C, the board also provides 2 I2C addresses for you to select as you want.
What is Grove?
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfil various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
Get Started with Industrial Sensors
SenseCAP S210x series industrial sensors provide an out-of-box experience for environmental sensing. Please refer to the S2101 Wireless Temperature and Humidity Sensor with higher performance and robustness for air temperature and humidity detection.
BMP280 vs. BME280 vs. DPS310
iTEMGrove-BMP280Grove-BME280Grove-DPS310
Pressure Range300 ~ 1100 hPa300 ~ 1100 hPa300 ~ 1200 hPa
Temperature Range-40 ~ 85 ℃-40 ~ 85 ℃-40 ~ 85 °C.
Pressure Precision--± 0.002 hPa (or ±0.02 m)
Pressure Accuracy
(Absolute)
± 1 hPa (or ±8 m)± 1 hPa (or ±8 m)± 1 hPa (or ±8 m)
Pressure Accuracy
(Relative)
± 0.12 hPa± 0.12 hPa± 0.06 hPa (or ±0.5 m)
Pressure Resolution0.18 Pa0.18 Pa0.06 Pa
Humidity-0 ~ 100%-
CommunicationI2C/SPII2C/SPII2C/SPI
Price$8.9$17.0$5.9
Application
  • Weather Station and Weather Sensing
  • Measure Temperature, Pressure, and Altitude
Note
As the sensor is quite sensitive to environmental conditions, please DO NOT touch it with your fingers.
Upgrade to Industrial Solutions
With the SenseCAP S2110 Grove converter and S2100 data logger, you can easily turn the Grove into a LoRaWAN® sensor. Seeed not only helps you with prototyping but also offers you the possibility to expand your project with the SenseCAP series of robust industrial sensors.
Supply Voltage
5V or 3.3V
Current Consumption
0.6 mA
Dimensions
130mm x90mm x8.5mm
Interface
I2C and SPI
I2C address
0x77(default) and 0x76
Barometric Pressure Measure
 Range
300 – 1100 hPa
Accuracy
±1.0 hPa
Temperature Measurement
Range
-40℃ to 85℃
Accuracy
±1℃
Grove - Barometer Sensor (BMP280)1
認証
HSCODE9026900090
USHSCODE9026902000
UPC841454118527
EUHSCODE9013101000
COOCHINA
Grove Temperature and Barometer Sensor (BMP280) - Supports I2C and SPI
SKU 101020192
Grove - BMP280 I2C and SPI Barometric and Temperature Sensor is built around Bosch BMP280. It is a low-cost and high-precision environmental sensor measures the temperature and barometer. Grove - BMP280 supports both I2C and SPI communication and we provide the BMP280 Arduino library.
USD$9.80
product.detail.alsoAdd.title
