The Grove - HCHO Sensor can be used to detect VOCs, such as HCHO, toluene, benzene, and alcohol which is Built with VOC sensor WSP2110 and Up to 1ppm high sensibility.
The Grove - HCHO Sensor is a semiconductor VOC gas sensor. It uses the VOC sensor WSP2110 whose conductivity changes with the concentration of VOC gas in the air. With a circuit, the conductivity can be converted to an output signal that corresponds to the gas concentration. This sensor has very high sensitivity and stability, it can detect gas whose concentration is up to 1ppm. It can be used to detect Toluene, Methanal, Benzene, Alcohol, Acetone etc. This product can be used to detect the presence of harmful gas in the home environment. It can be a good assistant to improve indoor air quality.
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfil various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
Operating Voltage |
5.0V ± 0.3V |
Chip |
WSP2110 |
Detection Gas |
toluene, methanal, benzene, alcohol, acetone &etc. |
Detection range |
1~50ppm |
Sensor Resistance Value(Rs) |
10KΩ-100KΩ(in 10ppm HCHO) |
Sensitivity |
Rs(in air)/Rs(10ppm HCHO)≥5 |
| Grove - HCHO Sensor | 1 |
| Grove - cable | 1 |
