おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
This IR Distance Interrupter features a high-sensitivity RFR-359F photoreflector to perform distance detection function. The photoreflector consists of a GaAs infared light emitting diode and a silicon planar phototransistor. When the infrared light emitted by the emitter gets reflected on a surface that blocked it, the phototransistor can pick up the signal for distance calculation. This module is panel mounted so that you can easily implement it on the surface of robots or other projects without wiring clutter. Also a potentiometer for adjustment and an indicator LED are arranged on the back for easy and clear use.
  • High sensitivity photoreflector
  • Lightweight and compact
  • Panel mount design for clean and tidy implementation
  • Clear HID design: adjustment potentiometer and indicator LED
Application Ideas
  • Wanderer robots
  • RPM gauges
  • Approximation detection
認証
HSCODE9031900090
USHSCODE9031902100
UPC841454108108
COOCHINA
技術詳細
Dimensions20mm x20mm x14.5mm
WeightG.W 6g
BatteryExclude
部品リスト
Grove - IR Distance Interrupter1
Grove - Cable1
SKU 101020040
USD$2.90
廃番
product.detail.alsoAdd.title
