おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Feature
  • Work efficiently under 3.3V and 5V
  • Support with both Arduino and Rasberry Pi
  • Compact size for easy deployment
  • Probe replaceable
An Oxidation Reduction Potential (ORP) Sensor measures the activity of oxidizers and reducers in an aqueous solution, it measures the ability of a lake or river to cleanse itself or break down waste products. The Grove OPR sensor works for both 3.3V and 5V system, the Grove connector and BNC probe interface make it easy to use and very suitable for Arduino and Raspberry Pi project.
Note
This ORP Sensor is no longer restocked, please reference the new version of ORP Sensor (HR-O), which is better than the old version
ItemsValues
Electrode potential245-270mv(15-30℃)
RangeReference electrode internal resistance≤10k
Resolution Electrode stability±8mv/24
Indicator electrodeGood continuity
Work voltage3.3V/5V
Work temperature5℃-70℃
Cautions
  • When measuring the electrode, the test part of the electrode (including platinum wire and reference junction) must be submerged at the same time.
  • The electrode standard solution-quinone hydroquinone saturated solution, the storage time is 48h. (Attachment: Preparation of quinone hydroquinone saturated solution: add excess quinone hydroquinone to the pH 4.00 buffer to make it saturated).
  • If the platinum wire of the electrode is stained with grease, it can be scrubbed with absorbent cotton and acetone or alcohol. And if it is dipped by insoluble inorganic substance, 30-50% hydrochloric acid works as well. Besides, it can also be cleaned by senior toilet paper once every day.
Part list
ItemsQuantity
ORP prober1
Grove cable1
Driver board1
What is Grove?
Grove makes it easier to connect, experiment, and simplify the prototyping process. No jumpers or soldering required. We have developed more than 300 Grove modules, covering a wide range of applications that can fulfil a variety of needs. Not only are these open hardware, but we also have open-source software.
Note
For all Grove users (especially beginners), we provide you with the guidance of operation. Please read the instructions through the official website before your using the product.
認証
HSCODE9031809090
USHSCODE9026806000
UPC841454123170
EUHSCODE9013101000
COOCHINA
Grove - ORP Sensor Kit (501Z)
SKU 110020293
This product is a cost-effective ORP sensor and easy to utilize, suitable for Arduino and Raspberry Pi, supports 3.3V and 5V system.
HR-O
USD$43.90
廃番
product.detail.alsoAdd.title
