製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Grove- Piezo Vibration Sensor is suitable for measurements of flexibility, vibration, impact and touch. The module is based on PZT film sensor LDT0-028. When the sensor moves back and forth, a certain voltage will be created by the voltage comparator inside of it.
Therefore, outputs high & low levels. In spite of the fact that it has a high receptivity for strong impacts, a wide dynamic range (0.001Hz~1000MHz) also guarantees excellent measuring performance. Finally, you can adjust its sensitivity by adjusting the potentiometer with a screw.
  • Standard grove socket
  • Wide dynamic range:0.001Hz~1000MHz
  • Adjustable sensitivity
  • High receptivity for strong impact
Applications
  • Vibration Sensing in Washing Machine
  • Low Power Wake-up Switch
  • Low-Cost Vibration Sensing
  • Car Alarms
  • Body Movement
  • Security Systems
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
認証
HSCODE9031900090
USHSCODE9031902100
UPC841454107842
EUHSCODE9013101000
COOCHINA
技術詳細
Dimensions40mm x20mm x11.5mm
WeightG.W 12g
BatteryExclude
部品リスト
Grove - Piezo Vibration Sensor1
SKU 101020031
Capable of withstand strong impact Wide dynamic range from 0.001Hz to 1000MHz Adjustable sensitivity Cost effective Grove connector compatible
JPY¥1093.00
