おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Note
This servo requires an operating voltage between 4.8V and 6.0V (5V typical). Voltages below the minimum 4.8V (e.g., 3.3V) are insufficient and will prevent correct operation. Always use a power supply providing voltage within this specified range.
Grove-Servo is a rotary actuator that allows for precise control of the angular position. It's suitable for use in closed-loop systems where precise position control is needed. We regulated the three-wire servo into a Grove standard connecter. You can plug and play it as a typical Grove module now, without jumper wires clutter.
  • High Accuracy: closed-loop control of position, speed and torque is achieved
  • High Stability: stable operation at a low speed of 0.12/0.16s/60°
  • Easy to use: compatible with Grove port, just plug-and-play
In this year's school season, Cornell University introduced a course called Human-Centered Design Methods. This course explores the use of design methods to generate ideas and evaluate designed objects, environments, and interfaces.
Students are expected to create an interactive object as the learning outcome. For example, an object that may light up, change color, make sounds, and/or move or change shape - when someone does something (near or far from it) or something happens (near or far from it).
Thus, here we highly recommend these products for the project
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfill various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
Application
  • Robotics
  • Printing equipment
  • Packaging equipment
認証
HSCODE8501101000
USHSCODE8501104080
UPC841454116059
EUHSCODE8501109390
COOCHINA
技術詳細
Dimensions60mm x60mm x14.5mm
WeightG.W 12.5g
BatteryExclude
部品リスト
Grove - Servo1
Cable1
Servos Horn3
Screw3
Grove - Servo
SKU 316010005
The Servo motor is a rotary actuator that allows for precise control of angular position which makes them suitable for use in closed-loop systems where precise position control is needed and is commonly used in electronics.
Grove - Servo is a bonus product for Grove lovers as we regulated the three-wire servo into a Grove standard connecter. You can plug and play it as a typical Grove module now, without jumper wires clutter.
USD$6.90
product.detail.alsoAdd.title
