製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Grove - Time of Flight Distance Sensor-VL53L0X is a high speed, high accuracy and long-range ToF distance sensor based on VL53L0X.
The VL53L0X is a new generation Time-of-Flight (ToF) laser-ranging module housed in the smallest package on the market today, providing accurate distance measurement whatever the target reflectances, unlike conventional technologies. It can measure absolute distances up to 2m, setting a new benchmark in ranging performance levels, opening the door to various new applications.
The VL53L0X integrates a leading-edge SPAD array (Single Photon Avalanche Diodes) and embeds ST’s second generation Flight SenseTM patented technology.
The VL53L0X’s 940 nm VCSEL emitter (Vertical-Cavity Surface-Emitting Laser), is totally invisible to the human eye, coupled with internal physical infrared filters, it enables longer ranging distances, higher immunity to ambient light, and better robustness to cover glass optical crosstalk.
Note
We've Released the Grove Selection Guide and hope to help you find the Grove suit you best.
Fully integrated miniature module
  • 940 nm laser VCSEL
  • VCSEL driver
  • Ranging sensor with an advanced embedded microcontroller
Fast, accurate distance ranging
  • Measures absolute range up to 2 m
  • The reported range is independent of the target reflectance
  • Advanced embedded optical cross-talk compensation to simplify cover glass selection
Eye safe
  • Class 1 laser device compliant with latest standard IEC 60825-1:2014 - 3rd edition
Easy integration
  • Single power supply
  • I2C interface for device control and data transfer
  • Xshutdown (reset) and interrupt GPIO
  • Programmable I2C address
Exclusion Cone
認証
HSCODE9031900090
USHSCODE9031808085
UPC841454120674
EUHSCODE9013101000
COOCHINA
技術詳細
Dimensions20mm x20mm x11mm
WeightG.W 7.8g
BatteryExclude
Working voltage3.3v/5v
Working temperature-20℃ - 70℃
Recommed measure distance30mm-1000mm
Resolution1mm
Infrared emitter940 nm
Default IIC Address0x52
部品リスト
Grove - Time of Flight Distance Sensor 30 to 1000mm(VL53L0X)1
Grove cable1
Grove - Time of Flight Distance Sensor(VL53L0X)
SKU 101020532
JPY¥1251.00
