This product will EOL soon, please consider the Grove - Variable Color LED V1.1 as alternative choice. Thank you!
This product consists of one 8mm RGB LED. It operates at 5V DC. When SIG pin is logic LOW, the RGB LED will show. Perfect for use on Seeeduino digital outputs, or also can be controlled using pulse-width modulation. And uses three adjustable resistor to change the color of the RGB LED.
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
| Dimensions | 130mm x90mm x19mm |
| Weight | G.W 7g |
| Battery | Exclude |
| Grove - Variable Color LED | 1 |
| Grove Cable | 1 |
