製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Integrated elevator control and cross-floor delivery
  • Laser vision and high intelligence
  • Smart body; ramps climbing and gaps passing
  • Rich port options and high scalability
Hermes robot platform features a built-in proprietary SLAMTEC core localization and navigation. Using 360° lidar and 2 depth camera systems, the robots can realize industry-leading autonomous movement and stable localization and navigation functionality specifically optimized for commercial service scenarios such as smart delivery, disinfection, and patrol.
Hermes provides the innovative Smart Elevator 3.0 solution, which allows elevator self-riding and obstacle avoidance in cross-floor buildings. SLAMTEC also provides one – stop services of elevator control system installation and on-site services to help developers quickly verify and realize the deployment of robot applications.
  • Cross-Floor Moving Solution, Smart Delivery
Hermes is equipped with SLAMTEC’s proprietary cross-floor moving solution, which is capable of automatically swapping between different floor maps. The robot provides cross-floor path-finding and obstacle avoidance functionality to realize smart delivery for commercial scenarios such as hotels, restaurants, buildings, and commercial centers.
  • Smart Elevator Control for Self-Ride Elevators
 Hermes supports the integration of SLAMTEC’s smart elevator control solution with most elevators on the market. Hermes can monitor elevator statuses in real time, supports multiple elevator call modes, and realizes smart robot calling and self-riding.
  •  Multiple Depth Cameras for Blind Spot-Free Path-Finding
Hermes is supported by lidar navigation and equipped with multiple depth camera sensors, 360° full range navigation and obstacle avoidance, zero blind spots, with stable and reliable localizing and navigating performance.
  • Dedicated Safety Sensor
To ensure safety in complex and dynamic environments, Hermes provides collision avoidance and boundary sensors to eliminate the collision and falling risks of obstacles such as steps, and bar tables and chairs.
  • Built-In Standalone Scalable Android System, No Hardware Required
The built-in scalable Android system of Hermes helps save costs as it does not require additional hardware or computing resources.
  • Highly Reliable Path-Finding and Strong Adaptability to Environmental Changes
Hermes uses SLAMTEC’s proprietary localization and navigation system to provide cutting-edge and highly reliable path-finding functionality. Hermes is capable to work correctly in many complex environments, such as heavily changing environment (ex. changing rate up to 60%), and the environment full of active obstacles (ex. people).
  • Super Obstacle Avoidance Functionality
With the superior structural and algorithmic design, Hermes features 20° ramp passing capability with excellent performance, even on thick carpet surfaces. The ability of Hermes to avoid an obstacle up to 20 mm in height makes it adaptable to a variety of scenarios.
  • Simple Deployment, Easy O&M, and One-Stop Service Installation and On-site Configuration
Built on SLAMTEC’s autonomous localization and navigation solution, Hermes does not require scenario-based adjustment or QR code navigation. SLAMTEC provides users of the Hermes with professional backend cloud services, and installation and on-site configuration scenarios for smart elevator control hardware. SLAMTEC’s professional technicians provide on-site, one-stop, zero-deployment, simple O&M, and worry-free services.
  • Cloud Layer Multi-Robot Collaboration + Multi-Point Delivery Support
Hermes supports local area network (LAN) and cloud platform collaborative operations, along with the dynamic adjustment of both speed and delivery routes in accordance with the environment to realize efficient, safe, and reliable multi-point delivery.
  • Other Hermes Features
  Windows/Linux/Android/iOS Platform Development Supported
  No Network Restrictions
  Autonomous Recharging
  5G Dual-Band Wi-Fi
  Remote Cloud Management
Specifications
Product Specifications
NameHermes
Core FeaturesIntegrated Elevator Control for Autonomous Self-Riding
Moving Tasks for Cross-Floor Buildings
SLAM Localization and Navigation
ItemIndexValue
Mass and VolumeLength x Width545 x 465 mm
Height272 mm (excludes controller)
Weight40 kg (excludes controller)
Max Load60 kg
Sensor Performance ParametersLidar SensorMax Scan Radius25 m (Standard), 360°
(90% Reflective Rate)30 m (Optional), 360°
Depth Camera SensorQuantity2 units
Detection Range0.2m-10m
Field of View (FOV)H: 135°V: 58°
Boundary SensorQuantity2 units
Min Detection Range1 cm
Bumper SensorQuantity2 units
Trigger MethodPhysical Collision
Embedded IMU SensorRobot Status Detection
Mapping PerformanceMap Resolution5 cm
Max Mapping Area500 x 500 m
Motion ParametersMax Move Speed1.5 m/s (Default: 1.2 m/s)
Max Cross Angle20°
Passing Obstacle Height2 cm
Passing Obstacle Width4 cm
Min Pass Range80 cm
User PortHardware PortEthernet1x RJ45 Gigabit Ethernet Port
Power Supply25 m (Standard), 360°
Wi-Fi2 units
4G0.2m-10m
SIM card slotH: 135°
V: 58°
HDMI2 units
Audio1x 3.5mm Headset Socket
1x LINE_MIC Audio Jack (Colay with headset socket)
1x Dual-Channel 5w / 8Ω Amplifier Jack
Type-CType-C
Standard USB 3.0 Type-C Port
Motion ParametersCapacity Specifications16Ah (Standard)
25Ah (Optional)
No-Load Operating Time7.5h (16Ah)
11.5h (25Ah)
Charging Time3h-4h
Power Dissipation in Stand-By Time24W
Battery Life600 complete charge and discharge cycles before 60% capacity reduction.
Charging Station25.5V 6A
Operating EnvironmentOperating Temperature’-10℃ to +50℃
Operating Humidity0%rh to 90%rh (no condensation)
Hermes Schematic Diagram
Application Scenarios
  • Hotel Delivery
  • Restaurant Delivery
  • Building Delivery
  • Commercial Patrol
  • Hospital Disinfection
  • Commercial Buildings
  • Airport Reception
Hermes-Cross-Floor Moving Robot Platform
1
認証
HSCODE8428904000
USHSCODE8428900390
UPC
EUHSCODE8471707000
COOCHINA
Hermes - Cross Floor Moving Robot Platform
SKU 110090341
Hermes is a scalable and low-cost robot platform capable of meeting the needs of small-to medium-sized robot application development in areas such as smart patrol robots, container transportation robots, hotel delivery robots, food delivery robots, and more.
JPY¥886333.00
廃番
