製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • High-quality camera with an 8 megapixel Sony IMX219 image sensor
  • Capable of viewing images at a high resolution of 3280 × 2464
  • High FOV (field-of-view) to capture more area
  • FCC and CE Certified
This is an 8-megapixel camera with a FOV (field-of-view) of 200 degrees, which is suitable to use with the NVIDIA Jetson Nano and NVIDIA Jetson Xavier NX Development Kits.
By using this camera, combined with a Jetson Nano/ Xavier NX Development Kits, you can simply realize machine vision projects. Also, you can experience better quality video capture from this camera and build more demanding projects!
More cameras compatible with NVIDIA Jetson Nano/ Xavier NX Development Kits
We would like to give you more freedom in choosing the camera that will be most suitable for your project. So, explore the table below to know about more cameras and make a better decision.
114992260114992261114992262114992263114992264114992265114992270
Diagonal Field of View (FOV)77°77°130°160°160°200°83°
IR LED ModulesNone2NoneNone2NoneNone
Aperture2.02.01.82.352.352.0/
Focal Length2.96mm2.96mm1.88mm3.15mm3.15mm0.87mm2.6mm
Lens Construction4P4P4E+IR6G+IR6G+IR1G4P+IR/
Distortion<1%<1%<7.6%<14.3%<14.3%<18.6%<1%
EFL2.93mm2.93mm1.85mm3.15mm3.15mm0.9mm/
BFL (Optical)1.16mm1.16mm1.95mm3.15mm3.15mm1.41mm/
Specifications
SpecificationDescription
Megapixels8 Megapixels
Photosensitive chipSony IMX219
Assembly TechniqueSMT (ROSH)
Resolution3280 × 2464
Pixel Size1.12µm x1.12µm
CMOS size1/4 inch
Aperture (F)2.0
Focusfixed
Focal Length0.87mm
Lens Construction1G4P+IR
Diagonal field of view (FOV)200 degrees
Distortion<18.6%
EFL0.9mm
BFL (Optical)1.41mm
Maximum Image Transfer Rate30 fps for QSXGA
Output formats8/10bit RGB RAW output
S/N Ratio39db
Dynamic Range69db
Sensitivity600mV/Lux-sec
Relative Illumination (Sensor)70%
IR Filter650±10nm
Object Distance30CM-∞
Interface15p-1.0 mipi
Power supply3.3V (pin15)
Operating Temperature-20°C to 70°C
Temperature (Stable Image)0°C to 50°C
Lens size6.5mm × 6.5mm
Module Size25mm × 24mm ×14±0.5mm
CertificationsFCC and CE
Parts List
  • 1 x IMX219-200 8MP Camera with 200° FOV - Compatible with NVIDIA Jetson Nano/ Xavier NX
  • 1 x 150mm FPC Cable
認証
HSCODE8525801390
USHSCODE8525895050
UPC
EUHSCODE8517600000
COOCHINA
SKU 114992265
77° IR
JPY¥4258.00
