the AI Hardware Partner
Toggle Nav
Loading...
SenseCAP Indicator for Meshtastic
It is a 4-inch touchscreen designed for Meshtastic, driven by dual MCUs ESP32 and RP2040, with support of Wi-Fi/BLE/LoRa® communication. It is a fully open-source, powerful IoT development platform.
Note:This product is still in the development stage. We will notify everyone once it's ready. Stay tuned.
    Node Device
    Sensor Quantity
    ¥1,736.47
    Antenna Quantity
    ¥393.07
    ¥299.94
    ¥393.07
    ¥393.07
    • Supports Meshtastic: Simply power it on, select the device in the Meshtastic Flasher, and flash the firmware to start using it.
    • Dual MCUs and Rich GPIOs: Equipped with powerful ESP32S3 and RP2040 dual MCUs and over 400 Grove-compatible GPIOs for flexible expansion options.
    • Real-time Air Quality Monitoring: Built-in tVOC and CO2 sensors, and an external Grove AHT20 temperature and humidity sensor for more precise
    • Local LoRa® Hub for IoT Connectivity: Integrated Semtech SX1262 LoRa® chip (optional) for connecting LoRa® devices to popular IoT platforms such as Matter via Wi-Fi, without the need for additional compatible devices.
    • Fully Open Source Platform: Leverage the extensive ESP32 and Raspberry Pi open-source ecosystem for infinite application possibilities.
    Screen
    3.95 Inch, Capacitive RGB Touch Screen
    Screen Resolution
    480 x 480 pixels
    Power Supply
    5V DC, 1A
    Battery
    N/A
    Processor
    ESP32-S3: Xtensa® dual-core 32-bit LX7 microprocessor, up to 240MHz
    RP2040: Dual ARM Cortex-M0+ up to 133MHz
    Flash
    ESP32S3: 8MB
    RP2040: 2MB
    External Storage
    Support up to 32GB Micro SD Card (not included)
    Wi-Fi
    802.11b/g/n, 2.4GHz
    Bluetooth
    Bluetooth 5.0 LE
    LoRa®(SX1262)
    LoRa®WAN/(G)FSK, 21dBm Max Transmitted Power Sensitivity/-136dBm@SF12 BW=125KHz RX Sensitivity, Up to 5km (depending on gateway antenna and environments)
    Sensors(Optional)
    Built-in CO2 (SCD41)
    Range: 0-40000ppm
    Accuracy: 400ppm - 5000ppm ±(50ppm+5% of reading)
    Built-in TVOC (SGP40)
    Range: 1-500 VOC Index Points
    External Temperature and Humidity Sensor
    Range: -40 ~ + 85 ℃/± 0.3 ℃; 0 ~ 100% RH/± 2% RH (25 ℃)
    Buzzer
    MLT-8530, Resonant Frequency:2700Hz
    Application
    If you've built a Meshtastic device, numerous potential applications await. Use the Meshtastic APP to communicate with low-power, long-range LoRa® devices via your phone. Connect with nearby nodes, participate in group chats, and share geographic locations—all in areas without cellular coverage.
    Recommended Use Cases:
    • Outdoor Adventure: Use this kit to set up a Meshtastic device, connected to a portable power bank, for off-grid communication with your hiking or camping group. The GPS helps track locations, while the temperature and humidity sensors provide real-time environmental data to ensure safety.
    • Environmental Monitoring: Collect and transmit environmental data. You can place it in your home or car as a Mesh node or repeater to detect the environment. Deploying this device in remote areas to monitor and record temperature and humidity changes over time helps in gathering local weather data.
