Product Details
Wiki & Learn
Reviews
Download PDF
The SV6301A is a handheld Vector Network Analyzer (VNA) with a 7" capacitive touchscreen. It offers a wide frequency range of 1MHz to 6.3GHz, precise S11 and S21 measurements, and a user-friendly interface. Certified by CE, FCC, and RoHS, this VNA demonstrates its commitment to providing a high standard of performance.
Feature
  • Wide Frequency Range: Supports a frequency range of 1 MHz to 6.3 GHz, making it suitable for a variety of high-frequency applications.
  • User-Friendly Interface: Equipped with a 7-inch IPS LCD capacitive touchscreen, providing an intuitive user interface for easy setup, data observation, and result analysis.
  • Precise S11 and S21 Measurements: With a dynamic range of 75 dB (S21) and 50 dB (S11) below 3 GHz, and 65 dB (S21) and 40 dB (S11) above 3 GHz, the SV6301A delivers accurate measurement and evaluation capabilities.
  • Fast Sweep Speed: Offers a rapid scan speed of 500 points per second for frequencies above 25 MHz, enabling quick measurements and analysis, and enhancing work efficiency.
  • Ample Storage and Calibration State Management: With 8GB of built-in storage capacity and support for TF card expansion, offers ample space for data storage.
With its wide frequency range of 1MHz to 6.3GHz, and precise S11 and S21 measurements, it offers accurate measurement and evaluation of transmission and reflection characteristics. Featuring a 7" capacitive touchscreen, the SV6301A offers a user-friendly interface for easy operation and data analysis. Additionally, with its ample storage capacity and calibration state management, users can conveniently store and manage calibration settings and measurement data, enhancing workflow and productivity.
The SV6301A finds applications across various fields, including communication system testing, RF engineering, wireless network research, antenna design, and microwave circuit analysis. With its advanced features and precise measurements, the SV6301A is an essential tool for high-frequency analysis and evaluation in a wide range of industries and research areas.
Application
  • Communication system testing
  • RF engineering
  • Wireless network research
  • Antenna design and testing
  • Microwave circuit analysis
Item
Condition
Frequency range
1MHz ~ 6.3GHz
RF power out
-40dBm ~ -10dBm
step:1dB
RF connectors
N-type female
Come with N-to-SMA adapters
RF power in
-100dBm (Max)
DC < 5V
Frequency accuracy
< ±1 ppm
Frequency step
10kHz (Min)
S21 dynamic range1
75dB
< 3GHz
65dB
> 3GHz
S11 dynamic range1
50dB
< 3GHz
40dB
> 3GHz
Sweep points
1001
Configurable from 101 to 1001
Sweep speed
500 pts/s
f > 25MHz
IFBW
12.5kHz (default)
12.5k/6.25k/3.12k/1k/300Hz/100Hz/30Hz
Smoothing
Arithmetic mean
Average times: 1 ~ 25
Traces
7
4 data traces, 2 reference traces, 1 TDR trace
Calibration state storage
18
Calibration states can be stored as files to the built-in memory card
Storage capacity
8GB
TF card
Display
7-inch IPS LCD
Resolution: 1024×600
Operation mode
Capacitive touch and physical buttons
Screenshot
On-device
Power consumption
6.5W
Battery life
3 hours
50% brightness
Battery
18650 lithium battery
3.6V/3350mAh×2
Charge/data port
USB Type-C
Charge voltage
4.7V ~ 5.5V
5V/2A is recommended
USB power output
5V/1A
Dimensions
190mmx130mmx30mm
RF connector not included
Shell material
Iron
Weight
1.2kg
1.7kg
Includes accessories and packaging
Operating temperature
0℃-45℃
Hardware Overview
SV6301A (with built-in 8GB memory card and 18650 battery x2)
x1
SMA open calibration piece
x1
SMA short calibration piece
x1
SMA load calibration piece
x1
N to SMA adapter
x2
SMA-KK adapter
x2
SMA-JJ adapter
x1
60cm SMA-JJ SS405 coaxial cable
x2
USB Type-C cable
x1
Storage bag
x1
Certification
HSCODE9030409000
USHSCODE9030400000
UPC
EUHSCODE9405413910
COOCHINA
Chelegance JNCRadio SV6301A – 6.3G VNA WITH 7” CAPA,CITIVE TOUCHSCREEN, PowerOut -40dBm ~ -10dBm, PowerIn -100dBm(MAX), 8GB TF card
SKU 109990525
JPY¥142130.00
