Note
SoM of Jetson Nano Developer Kit A02 will not work with Jetson Mate
Jetson Mate is a carrier board in which you can install up to 4 NVIDIA Jetson Nano/NX SoMs. There is an onboard 5-port Gigabit switch enabling the 4 SoMs to communicate with each other. All the 3 peripheral SoMs can be powered on or off separately. With a 65W 2-Port PD charger, for Jetson Nano SoMs or a 90W 2-Port PD charger for Jetson NX SoMs, and one ethernet cable, developers can easily build their own Jetson Cluster.
Note
The kit does not include a power adapter. Please use a 65W 2-Port PD charger, if you have Jetson Nano SoMs, and use a 90W 2-Port PD charger if you have Jetson NX SoMs
When all the SoMs are connected to Jetson Mate, it will look like below
Note
SoMs are not included in the package.
Specification | Details |
Onboard 5-Port Gigabit Switch | Microchip KSZ9896CTXC |
Power | 65W PD for Jetson Nano SoMs 90W PD for Jetson NX SoMs |
Dimensions | 110mm x 110mm |
At Seeed, you can also design your solution all in one page where you choose the desired SBC, any compatible mission board (HATs, expansions) that you want, I/O modules, and nicely place them in the suitable enclosures/cases such as re_computer case. Rest assured, as we have tested full compatibility for all of the products listed on the page. Try it now here and save you time to find hardware compatibility!
