おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Fully compatible with NVIDIA Jetson Nano Module.
  • Essential for high-intensity work: Featuring a full aluminum alloy heatsink and a 7-blade fan mechanism, this design provides efficient physical cooling that helps to prevent overheating and CPU throttling.
  • Convertible Interface: Support both Graphics Card 4-pin connector and Mainboard Standard 4-pin connector
  • Customized Air Speed: Utilize PWM to control the fan speed
  • Easy to install: Mounting Holes & bolts Included
仕様
Items
Unit
Parameters
Notes
Dimensions
mm
40mm x 40mm x 15mm
Fan Frame
BLACK PBT (UL94V-0)
Glass Fiber Reinforced
Fan Impeller
BLACK PBT (UL94V-0)
7 Blades
Bearing System
Dual Ball Bearing
Rated Power
Watt
0.4
At rated Voltage,Measured after 3 mins.
Rated Speed
RPM
5500±10%
Air Flow
CFM
2.95
Maximum In Free Air,Refer to 4.2.
Air Pressure
mmAq
2.95
Maximum When Air Flow = 0
Noise Level
dBA
23.71
At Rated Speed,Refer to 4.3
Motor Protection
Polarity Protection
Yes
Operating Voltage Range
VDC
4.5-5.5
At 25°C/Relative Humidity65%
Pinout Definition
Black
Red
Yellow
Blue
FG(Tachometer Signal)
PWM
ドキュメント
認証
HSCODE8414599060
USHSCODE8473305100
UPC
EUHSCODE8414591500
COOCHINA
部品リスト
Jetson Nano Module Active Heat Sink
x1
1.25 mm 4-pin connector
x1
1.25mm to 2.54 mm 4-pin connector
x1
NVIDIA® Jetson Nano™ Active Heat Sink
SKU 101110061
The Jetson Nano Module Active Heat Sink provides essential and strong physical cooling for the Jetson Nano's high-intensity workloads, using a 7 blades fan mechanism for active air cooling. It allows for customizing fan speed through PWM, which helps to avoid overheating and throttling issues. It can be customized to air flow speed through PWM function.
Aluminum Heatsink for Jetson Nano Module
USD$11.94
$19.90
Save $7.96(40%)
product.detail.alsoAdd.title
