おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
With an IP68 waterproof rating, the junction box can be used to connect S2100 Data Logger with an external 12V power supply. No additional tools, no welding or cutting of cables is required which makes connection easier and safer.
  • Industrial Standard: IP68 high waterproof level
  • Premium Material: premium plastic enclosure
  • Easy to Install: kit includes a screwdriver, waterproof tape and screws, etc. for quick installation and can be installed horizontally or vertically as an external junction box
Steps to Connect Data Logger with Junction Box
1. Wire to the terminal of the Data Logger.
2. Wire to the terminal of the junction box.
3. Connect the sensor wire to the junction box.
4. Connect the 12V DC adapter to the power supply.
Model
Junction-Box-Kit
Material
Housing
Conductor
PC
Brass
IP code
IP68
Working temperature
T105
Rated connecting capacity
0.5 ~2.5mm²
Available cable diameter
(Rubber cable)
4-8mm
Waterproof test
10M 150hours
Product size
130.14mm*80.5mm*35.3mm
(Refer to actual drawing)
Certification
KEMA,ENEC,CE,UKCA,CB,SAA,ROHS
Dimension
Partlist
Housing
1
M12 Cable
1
Self-tapping Screw
8
Screwdriver
1
Waterproof Tape
1
Connection Terminal
2
Q1: Is it only available for the S2100?
No. It can be used in any situation where you need to use wiring and external connection.
Q2: How many cables can it connect to?
12
Q3: Are there any precautions during installation?
Tighten the screws and screw caps to check the waterproofing. If the cable diameter is too thin, add waterproof tape for winding.
認証
HSCODE8517799000
USHSCODE8536694010
UPC
EUHSCODE8517180000
COOCHINA
Waterproof Junction Box Kit, IP68 Terminal Box, Connecting Box for S2100 Data Logger
SKU 114992988
With an IP68 waterproof rating, the junction box can be used to connect S2100 Data Logger with an external 12V power supply. No additional tools, no welding, or cutting of cables is required which makes connection easier and safer.
JPY¥1504.00
product.detail.alsoAdd.title
