製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
All-in-one features
Includes ARM7 EJ-S™, GSM, GPRS, Wi-Fi, Bluetooth BR/EDR/BLE, GPS, Audio codec, and SD card connector on a single development board
Rich-Compatibility
Pin-out similar to Arduino boards, including Digital I/O, Analog I/O, PWM, I2C, SPI, UART and power supply, compatible with Grove 4-pin interface
Strong Extensibility
Provides various interfaces for connecting to most sensors, peripherals, Groves, and other widgets
Easy Prototyping
You are what you wear. Using LinkIt ONE together with MediaTek LinkIt SDK (for Arduino) you will be able to easily turn your ideas into practical prototypes and make them a reality with the Seeed productization and agile manufacturing service.
What is LinkIt ONE
The LinkIt ONE development board is an open source, high-performance board for prototyping Wearables and IoT devices. It's based on the world's leading SoC for Wearables, MediaTek Aster (MT2502) combined with high-performance Wi-Fi (MT5931) and GPS (MT3332) chipsets to provide you with access to all the features of MediaTek LinkIt. It also provides similar pin-out features to Arduino boards, making it easy for you to connect to various sensors, peripherals, and Arduino shields.
LinkIt ONE is a co-design product by Seeed Studio and MediaTek. It brings together the parties' knowledge in open hardware and industry-leading reference designs for Wearables and IoT devices to create this powerful development board.
LinkIt ONE development is fully supported on the MediaTek Labs site: check out the LinkIt section and register here to download the SDK, participate in the Forums, and more.
Schematic Diagram
LinkIt ONE is built to offer similar pin-out to the popular Arduino boards ,4-pin grove interfaces and peripheral interfaces, making it easy to add sensors, peripherals, and Arduino Shields to LinkIt ONE and create fully featured wearable and IoT device prototypes. Here you can reach some widgets to have a comprehensive understanding of this platform, and we will develop more one after another.
Package
LinkIt ONE is paicked in the protective box, along with a quick start guide, pin-out diagram relevant user mannual and accessories. The box is designed to protect the LinkIt ONE from can prevent the shocks and impact. And for retailer which you may hang on the box in your a physical store, the box may include with a pendant from which it can be hung for display.
Box
LinkIt ONE BoardAntennaPolymer li-ion Battery
認証
HSCODE8517180050
USHSCODE8517180050
UPC841454106326
EUHSCODE8543709099
COOCHINA
技術詳細
Dimensions108mm x75mm x33mm
WeightG.W 102.5g
BatteryLithium Cells/Batteries packed with equipment UN3481 -PI966
Microcontroller
ChipsetMT2502A (Aster)
CoreARM7 EJ-S™
Clock Speed260MHz
Dimensions3.3 x 2.1 inches
Flash16MB
RAM4MB
Battery Jack3.7~4.2V Li-battery
DC Current Per I/O Pin0.3~3mA
Pin Count16 (D0~D13, SDA, SCL)
Voltage3.3v
Pin Count3 (A0, A1, A2)
Voltage0~5V
Pin Count2 (D3 and D9)
Voltage3.3v
Max Resolution13bit
Frequency (Resolution)1.6KHz (13bit) / 50.8KHz (8bit) / 800KHz (4bit)/ (customizable)
Pin Count2 (D2 and D3)
Set Count1 (SDA, SCL)
Speed100Kbps, 400Kbps, 3.4Mbps
Set Count1 (MOSI, MISO, SCK, SS)
Speed104Kbps~26Mbps
Set Count1 (TX/RX)
Voltage3.3v
Set Count1
GSM850/900/1800/1900MHz
GPRSClass 12
BluetoothBR/EDR/BLE (Dual Mode)
Wi-Fi (MT5931)802.11 b/g/n
GPS (MT3332)GPS/GLONASS/BEIDOU
Flash10MB
SD CardUp to 32GB (Class 10)
RAM (Code+RO+RW+ZI+Heap)2MB
部品リスト
LinkIt One1
LinkIt ONE
SKU 102030002
Co-design by Seeed and MTK High performance board for wearable and IoT Rich - Features Rich - compatibility Strong extensibility, similar pinout to Arduino
JPY¥9339.00
廃番
