LinkStar-H68K portable router equips quad-core Cortex-A55 RK3568 chip, featuring 4 Ethernet interfaces for dual-2.5G and dual-1G while providing great extensibility and media player functionality, functioning recommended for indoor use.
LinkStar-H68K equips quad-core Cortex-A55 RK3568 chip, featuring dual-1G Ethernet and dual-2.5G Ethernet as 4 network interfaces overall, assembled in one portable metal box, designed for high-speed network. It comes with sufficient expansion ability and media player functionality, presenting you with a fully functional device for office work and home entertainment, as well as anywhere you travel around.
This compact equipment equips onboard 32GB eMMC, along with one SD card slot and one USB3.0 Type-C which supports an external hard drive for storage extension. Combined with fast-speed Ethernet, you can use it to establish a NAS(Network Attached Storage) to store and access abundant information over a network without physical file transformation.
With such storage and network capability, it houses an HDMI 2.0 port and a 3.5mm microphone port, installing Android 11 OS in advance, outputting 4K immersive visual, all of which make it a neat network media player to stream media and display instantly, while providing access to online services like Spotify or YouTube.
Additionally, it provides an SD card slot, one USB 3.0, and two USB 2.0 ports for further usage. You can connect a USB printer with it for print serving in the office which can be available to the entire network. Meanwhile, you can switch to a different Operating System by inserting different SD cards without overwriting the original one.
Not only Linux systems like Lubuntu 20.04, but you can also run it with a dedicated routing system like OpenWRT for building a fast speed and secure router in concentration. You can utilize it to establish a VPN router of your own, realize remote control, block advertising, and other personal customization by your definition.
The design of LinkStar-H68K is light and mini-sized that it can be lifted by one singular hand. It is built around metal for passive heat dissipation. You can charge it with a 5-24V power adaptor and 5V Type-C connector. It is your HTPC for home entertainment, or an office PC connected to video conferencing on your business trip.
Note
Parameters |
Details |
Processor |
Rockchip RK3568 for up to 2.0GHz |
CPU |
Quad-core 64-bit Cortex-A55 |
GPU |
ARM G52 2EE |
NPU |
1 TOPS@INT8 |
Multi-Media |
4K@60fps H.265/H.264/VP9 video decoder 1080@60fps H.265/H.264 video encoder |
Support 8M ISP, HDR | |
Storage |
onboard 32GB eMMC |
1x SD card slot for storage expansion | |
1x PCIe2.0 for Wi-Fi or M.2 extension | |
Operating System |
Pre-installed Android 11 OS |
Support Lubuntu 20.04, Armbian, Android, Openwrt, Buildroot | |
NIC |
2x 1G Ethernet NIC RTL8211F |
2x 2.5G Ethernet NIC RTL8125B | |
Video Output |
1x HDMI2.0 interface for 4K output |
Audio |
1x 3.5mm four-piece headphones for both input and output |
USB |
1x USB 3.0 Type-A |
1x USB 3.0 Type-C, capable of storage expansion and 5V power supply | |
2x USB 2.0 Type-A | |
Power Supply |
operating voltage: 5V~24V DC(12V-1A DC recommended) |
recommend: 12V-1A DC | |
recommend(with additional hardware driver): 12-2A DC | |
recommend(with Type-C connector): under 5V | |
Power Consumption |
6W(With a fully loaded network port) |
Operating temperature |
-10 ~ 55°C |
Dimensions |
80*60*40mm |
LinkStar-H68K-0232 | X1 |
If you want to use an SD card to switch to OpenWRT OS, the main board should be installed on Android OS in eMMC to support it.
| HSCODE | 8471419000 |
| USHSCODE | 8517180050 |
| UPC | |
| EUHSCODE | 8471707000 |
| COO | CHINA |
LinkStar-H68K portable router equips quad-core Cortex-A55 RK3568 chip, featuring 4 Ethernet interfaces for dual-2.5G and dual-1G, while providing great extensibility and media player functionality, functioning well both indoors and outdoors, whether for traveling or stationary.
