製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
About SenseCAP
Among the first launch of Seeed industrial IoT (IIoT) product series, SenseCAP is focusing on wireless environmental sensing applications: smart agriculture, precision farming, and smart city, to name a few. It consists of hardware products (sensors, data-loggers & gateways, etc.), software services (SenseCAP portal, mobile App, open dashboard), and API for device & data management. SenseCAP supports different communication protocols, such as LoRa, 2G, 4G, NB-IoT, and more.
Note
Please send email to sensecap[at]seeed[dot]cc to request any technological support for this product.
SenseCAP Wireless Barometric Pressure Sensor measures atmospheric pressure in the range of 300~1100 hPa. Featuring high-precision, stability, and high EMC robustness, this sensor is suitable for industrial applications such as weather stations, outdoor farms, tea plantations, greenhouses, and more.
This device incorporates a built-in LoRa transmitter based on SX1276 for long-range transmission, a barometric sensor, and a custom battery. It is specifically designed and optimized for use cases powering end devices by batteries for years. To minimize the power consumption, the device wakes up, transmits the collected air pressure data to the gateway, and then goes back to sleep.
Under the best of circumstances, the battery is expected to last for more than 8 years, depending on the environmental factors and data transmission intervals. Please kindly note that the default interval is once per hour. If you'd like to change the data upload interval, please refer to this document.
SenseCAP Sensor adopts a modular design, integrating the data-logger with the sensor probe, which can be replaced by other SenseCAP sensor probes. This sensor's data logger is rated IP66, and the sensor probe is rated IP65.
Note
SenseCAP Sensor is fully compliant with LoRaWAN specifications and can be used with standard LoRaWAN gateways. Please choose the corresponding gateway according to the sensor frequency. Seeed also provides SenseCAP LoRaWAN Gateway for you to use with SenseCAP Sensors seamlessly without extra huge workload for provisioning.
System Architecture
SenseCAP Architecture
SenseCAP Sensor + Other LoRaWAN Gateway Architecture
  • Support LoRaWAN protocol Class A
  • High reliability and stability
  • Ultra-wide-distance transmission: 10km in line of sight scene, 2 km in urban scenes
  • Battery life ≥ 8 years
  • IP66 enclosure, suitable for outdoor applications
  • Rapid installation and deployment (see the video below)
Applications
  • Smart Agriculture
  • Smart Building and Industrial Control
  • Environmental Monitoring
  • Other Wireless Sensing Applications
Specifications
Barometric Pressure
ParametersConditionValue
Range-300~1100 hPa
Resolution-1 Pa
Relative Accuracy700 to 900 hPa
25 to 40 ℃
±0.12 hPa
Absolute Accuracy300 to 1100 hPa
-20 to 0 ℃
±1.7 hPa
0 to 65 ℃
±1.0 hPa
Temperature Coefficient Offset900 hPa
25 to 40 °C
1.5 Pa/K
Drift-±1.0 hPa/year
General Parameters
Product ModelLoRa-S-868-Baro-01
MicrocontrollerUltra-low-power MCU
Support ProtocolBased on LoRaWAN v1.0.2 protocol
LoRa Channel PlanEU868
LoRa Power Output16 dBm (EIRP)
Sensitivity-137.5dBm(SF12, BW125KHz)
Current Consumption5 μA (sleep mode)
120 mA max(active mode)
Communication Distance2 to 10 km (depending on different antennas and environments)
IP RatingIP66 (Sensor Node); IP65 (Sensor Probe)
UV Resistanceanti-aging (from rain/sun exposure): UL746C F1
Enclosure MaterialPC
Operating Temperature-40 to +85 ℃ (full accuracy: 0 to 65℃)
Operating Humidity0 to 100 %RH (non-condensing)
Device Weight237g
CertificationCE, FCC, RoHS
Battery (Contained in equipment)
Battery Life≥ 3 year (upload data once per hour)
Battery Voltage3.6V
Battery Capacity19Ah (non-rechargeable)
LoRa Frequency
The device is designed with a fixed LoRa channel, which can not be modified by users. The supported channels are as follows. Please refer to this document for how to connect this device with a LoRaWAN gateway.
LoRa Channel Plan
Uplink (MHz)868.1 - SF7BW125 to SF12BW125
868.3 - SF7BW125 to SF12BW125 and SF7BW250
868.5 - SF7BW125 to SF12BW125
867.1 - SF7BW125 to SF12BW125
867.3 - SF7BW125 to SF12BW125
867.5 - SF7BW125 to SF12BW125
867.7 - SF7BW125 to SF12BW125
867.9 - SF7BW125 to SF12BW125
Downlink (MHz)Uplink channels 1-8 (RX1)
869.525 - SF9BW125 (RX2 downlink only)
Tips
Apart from the EU868MHz version, this sensor is also available in US915MHz frequency. Click here to learn more.
1Sensorx1
2Bracketx1
3M4 Self-drilling Screwx4
4M3 Self-drilling Screwx2
認証
HSCODE9026209090
USHSCODE9026208000
UPC
EUHSCODE9013101000
COOCHINA
SenseCAP Wireless Barometric Pressure Sensor - LoRaWAN EU868MHz
SKU 114991729
SenseCAP Wireless Barometric Pressure Sensor measures atmospheric pressure, featuring high-precision, stability, and high EMC robustness. It’s designed with an air pressure sensor, a custom battery, and an industry-grade enclosure, optimized for outdoor use cases that need reliable data collection over years.
AU915
JPY¥15986.00
廃番
