製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
About SenseCAP
Among the first launch of Seeed industrial IoT (IIoT) product series, SenseCAP is focusing on wireless environmental sensing applications: smart agriculture, precision farming, and smart city, to name a few. It consists of hardware products (sensors, data-loggers & gateways, etc.), software services (SenseCAP portal, mobile App, open dashboard), and API for device & data management. SenseCAP supports different communication protocols, such as LoRa, 2G, 4G, NB-IoT, and more.
Note
Please send email to sensecap[at]seeed[dot]cc to request any technological support for this product.
SenseCAP Wireless CO2 Sensor measures the level of carbon dioxide (CO2) gas at the range of 0 ~ 40000 ppm in the atmosphere, applicable for indoor environments. It is perfect for monitoring CO2 ppm in greenhouses, industrial campuses, factories, schools, office buildings, hotels, hospitals, transportation stations, and anywhere that data of CO2 emission is needed.
This device incorporates a built-in LoRa transmitter based on SX1276 for long-range transmission, an NDIR CO2 sensor, and a custom battery. It is specifically designed and optimized for use cases powering end devices by batteries over the years. To minimize the power consumption, the device wakes up, transmits the collected CO2 data to the gateway, and then goes back to sleep.
Under the best of circumstances, the battery is expected to last for 1.5 years, depending on the data transmission intervals. Please kindly note that the default interval is once per hour. If you'd like to change the data upload interval, please refer to this document.
SenseCAP Sensor Node adopts a modular design, integrating the data logger with the sensor probe, which is replaceable by other SenseCAP sensor probes.
The data logger part is designed with industry standards and equipped with an IP66 waterproof enclosure. To ensure accuracy and sensitivity, we chose the material with the optimal breathable aperture for the sensor probe, which however is not waterproof. Hence, this CO2 Sensor is applicable only for indoor environments. The product is dustproof, making it ideal for environments such as chicken farms, where there is poultry dust.
Note
SenseCAP Sensor is fully compliant with LoRaWAN specifications and can be used with standard LoRaWAN gateways. Please choose the corresponding gateway according to the sensor frequency. Seeed also provides SenseCAP LoRaWAN Gateway for you to use with SenseCAP Sensors seamlessly without extra huge workload for provisioning.
System Architecture
SenseCAP Architecture
SenseCAP Sensor + Other LoRaWAN Gateway Architecture
  • Support LoRaWAN protocol Class A
  • NDIR CO2 sensor technology
  • Dual-channel detection for superior stability
  • Ultra-wide-distance transmission: 10km in line of sight scene, 2 km in urban scenes
  • Battery life ≥ 1.5 years
  • Rapid installation and deployment (see the video below)
Applications
  • Smart Agriculture/ Precision Agriculture
  • Smart Building and Industrial Control
  • Environmental Monitoring
  • Other Wireless Sensing Applications
Specifications
CO2
ParametersConditionValue
Range-0 to 40000 ppm
Accuracy400 to 10000ppm±(30 ppm + 3 %MV)
Resolution-1 ppm
Temperature StabilityT = 0 to 50 ℃±2.5 ppm/℃
Parameters
Product ModelLoRa-S-868-CO2-01
MicrocontrollerUltra-low-power MCU
Support ProtocolBased on LoRaWAN v1.0.2 protocol
LoRa Channel PlanEU868
LoRa Power Output16 dBm (EIRP)
Sensitivity-137.5dBm(SF12, BW125KHz)
Current Consumption5 μA (sleep mode)
120 mA max(active mode)
Communication Distance2 to 10 km (depending on different antennas and environments)
IP RatingIP66 (Sensor Node); Indoor (Sensor Probe)
UV Resistanceanti-aging (from rain/sun exposure): UL746C F1
Enclosure MaterialPC
Operating Temperature0 ℃ to +50 ℃
Operating Humidity0 to 95 %RH
Device Weight319g
CertificationCE, FCC, RoHS
Battery (Contained in equipment)
Battery Life≥ 3 year (upload data once per hour)
Battery Voltage3.6V
Battery Capacity19Ah (non-rechargeable)
LoRa Frequency
The device is designed with a fixed LoRa channel, which can not be modified by users. The supported channels are as follows. Please refer to user manual for how to connect this device with a LoRaWAN gateway.
LoRa Channel Plan
Uplink (MHz)868.1 - SF7BW125 to SF12BW125
868.3 - SF7BW125 to SF12BW125 and SF7BW250
868.5 - SF7BW125 to SF12BW125
867.1 - SF7BW125 to SF12BW125
867.3 - SF7BW125 to SF12BW125
867.5 - SF7BW125 to SF12BW125
867.7 - SF7BW125 to SF12BW125
867.9 - SF7BW125 to SF12BW125
Downlink (MHz)Uplink channels 1-8 (RX1)
869.525 - SF9BW125 (RX2 downlink only)
Tips
Apart from the EU868MHz version, this sensor is also available in US915MHz frequency. Click here to learn more.
1Sensorx1
2Bracketx1
3M4 Self-drilling Screwx4
4M3 Self-drilling Screwx2
認証
HSCODE9027100090
USHSCODE9027106000
UPC
EUHSCODE9027109000
COOCHINA
SenseCAP Wireless CO2 Sensor - LoRaWAN EU868MHz
SKU 114991728
SenseCAP Wireless CO2 Sensor measures levels of CO2 emission in the atmosphere, designed with an NDIR CO2 sensor and a custom battery. It's dustproof, optimal for use cases that need reliable data collection, even in dusted indoor environments such as chicken farms.
AU915
JPY¥28331.00
廃番
