製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
About SenseCAP
Among the first launch of Seeed industrial IoT (IIoT) product series, SenseCAP is focusing on wireless environmental sensing applications: smart agriculture, precision farming, and smart city, to name a few. It consists of hardware products (sensors, data-loggers & gateways, etc.), software services (SenseCAP portal, mobile App, open dashboard), and API for device & data management. SenseCAP supports different communication protocols, such as LoRa, 2G, 4G, NB-IoT, and more.
Note
Please send email to sensecap[at]seeed[dot]cc to request any technological support for this product.
SenseCAP Gateway - LoRaWAN is based on LoRaWAN protocol, applicable for low-power consumption, long-range environmental data collection, and remote monitoring scenarios such as smart agriculture and smart city.
As the central device of SenseCAP LoRaWAN network, the gateway is used for collecting data from different SenseCAP Sensors and transmit the data to the cloud platform via cellular LTE or Ethernet. Equipped with a high-performance processor AM3358 and telecom-operator-level LoRa chip SX1301, this device ensures robustness and high performance in large-scale networks. Mutual authentication and encryption are established in the whole network to increase security.
The gateway is designed with an IP66 enclosure and supports an extended operating temperature range, making it suitable for industrial applications in both indoor and outdoor severe environments.
We offer different SenseCAP Gateway - LoRaWAN with different ISM bands:
SenseCAP Gateway - LoRawan EU 868  ( subset of  863 - 870 MHz)
SenseCAP Gateway - LoRawan CN 470  ( subset of  470 - 510MHz)
Note
Please choose the corresponding frequency according to regional regulation.
SenseCAP mobile APP and SenseCAP Portal are provided to enable easy and efficient provisioning and management of devices & data at scale.
SenseCAP API is provided to access data and devices for further development.
Here is a collection of SenseCAP LoRaWAN sensors for you to use with SenseCAP LoRaWAN Gateway seamlessly without extra workload for provisioning. It only takes you a few minutes to set up with this instruction.
If you want to add other LoRaWAN sensors, no problem at all. Please kindly refer to this document to connect any LoRaWAN sensors to SenseCAP LoRaWAN Gateway.
System Architecture
SenseCAP Architecture
SenseCAP Sensor + Other LoRaWAN Gateway Architecture
    • High-performance Cortex A8 1GHz processor, Linux system.
    • Support LoRaWAN protocol Class A, support ultra-low-power SenseCAP Sensor
    • Support 8 RX, 1 TX transceiver, maximum transmit power 27dBm
    • Support multiple ISM bands: CN470, EU868, US915
    • Support multiple methods to access the network: 4G, Ethernet
    • Ultra-wide-distance transmission: 10km in line of sight scene, 2 km in the urban scene
    • Industrial grade protection: IP66 enclosure, temperature -40℃~70℃, suitable for outdoor applications
    • Easy deployment, and rapid provisioning (see the "how to install" video below)
Applications
  • Smart Agriculture
  • Smart Building
  • Environmental Monitoring
  • Other Wireless Sensing Applications
Specifications
General Parameters
Product ModelLoRa-G-868-E/4G
CPUTI AM3358 Cortex-A8 1GHz
SystemLinux Debian
RAMDDR3 512MB
Memory8GB eMMC
Channel Plan863~870MHz
LoRa Power Output25dBm
LoRa Sensitivity-139.5dBm (SF12BW125)
Ethernet100Mbps FE (RJ-45)
4G Band
LTE-FDD: B1/B2/B3/B4/B5/B7/B8/B12/B13/B18/B19/B20/B25/B26/B28
LTE-TDD: B38/B39/B40/B41
WCDMA: B1/B2/B4/B5/B6/B8/B19
GSM: 850/900/1800/1900MHz
4G Features
Support non-CA Cat 4 FDD and TDD
LTE-FDD: Max 150Mbps (DL), Max 50Mbps (UL)
LTE-TDD: Max 130Mbps (DL), Max 30Mbps (UL)
UMTS Features
Support 3GPP R8 DC-HSDPA, HSPA+, HSDPA, HSUPA and WCDMA
DC-HSDPA: Max 42Mbps (DL) HSUPA: Max 5.76Mbps (UL)
WCDMA: Max 384Kbps (DL), Max 384Kbps (UL)
LoRa Antenna
2.5dBi gain / Vertical polarization / Omni-directional / SMA-J connector
4G Antenna
0-4dBi gain / Linear polarization / Omnidirectional / SMA-J connector
LED IndicatorIndicating network condition (online/ offline)
GroundingReserved 1 screw hole for GND
Power Consumption3.6W
Power SupplyDC 12V/2A
IP RatingIP66
UV Resistanceanti-aging (from rain/sun exposure): UL746C F1
Enclosure MaterialPC
Operating Temperature-40 ℃ to +70 ℃
Operating Humidity0 to 100 %RH (non-condensing)
Installation MethodWall or pole mounting
Device Weight777g
Device Dimensions256mm * 160mm * 81mm
CertificationCE, FCC, RoHS
Interface
1LoRa Gatewayx1
2LoRa Antennax1
34G Antennax1
4Allen Hex Keyx1
5Mountsx4
6Power Adapterx1
7Power Extension Cable (5M)x1
8Ferrules / Aluminum piecex 2 / 2
9M5 Self-drilling Screwsx8
*Optional Antenna
1LoRa Fiberglass Omni Antennax1
2Antenna Lightning Protectorx1
3LoRa Antenna Bracketsx1
認証
HSCODE8517629990
USHSCODE8517620010
UPC
EUHSCODE8517180000
COOCHINA
SenseCAP Gateway - LoRaWAN EU868MHz
SKU 102991154
SenseCAP Gateway - LoRaWAN is an IP66 industrial-grade outdoor product, supports an extended operating temperature range, making it applicable for low-power consumption, long-range data collection IoT scenarios like smart farming.
Usage
Network Connection
Region
JPY¥59986.00
¥63152.00
Save ¥3166.00(5%)
