おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Mini AI Computer T906 is powered by Jetson AGX Orin 32GB Module, delivers up to 200TOPS AI performance, and is mounted with two ethernet ports for up to 10 Gbps communicating. Support Wi-Fi, Bluetooth, 4G/5G, and GPS enables hybrid fast network and navigation. The full system is ideal for building energy-efficient autonomous machines with the most advanced AI power, and industrial interfaces, and operating under excellent passive heat dissipation, two fans, along with IP55 lightweight aluminum alloy structure.
  • Cutting-edge edge AI platform:  powered by the latest Jetson AGX Orin 32GB for up to 200 TOPS AI performance, designed with advanced heat dissipation, integrated multiple functions, assembled with IP55 aluminum alloy.
  • Hybrid network access: equipped with 10 Gigabit & 1 Gigabit ethernets ports, support Wi-Fi(M.2 Key B), 4G(Mini PCIe), 5G(M.2 Key E).
  • Design for autonomous machines: Mounted with one JEG vehicle-level interface for radar sensors connecting and one GMSL camera connector for video transcoding, also carrying multiple industrial & robotic ports where there are 3x RS232
  • Advanced heat dissipation: assemble two fans onboard, combining with a high-efficiency passive heat dissipation design.
  • Simplify development: Pre-installed JetPack 5.0.2, support entire Jetson software stack and developer tools support, capable of building fast and various AI application provided by Seeed Edge AI partners
Note
Custom integrations with GPS, 4G, 5G, and WiFi/Bluetooth modules are also available, contact [email protected] for more details.
Mini AI Computer T906 built with the Jetson AGX Orin 32GB Module that delivers up to 200TOPS AI performance, ready for the most complex AI workloads at the edge. Pre-installed Jetpack 5.0.2, supported by NVIDIA JetPack and DeepStream SDKs, TensorRT, RIVA, Issac software libraries, and leading AI platform-tools from the Seeed Edge AI ecosystem, you can easily develop and deploy AI applications for manufacturing, delivery, retail, and smart cities, and more.
You can access a speed network access with ethernet ports of 10GbE and 1GbE at Mini AI Computer T906. You can enable up to 10 streams for video analytics.
The built-in carrier board also leaves interfaces for the GPS module, and M.2 Key M for extending SSD, M.2 Key B for the wifi module, M.2 Key E for 5G module,Mini PCIe for 4G module.
With 3x RS232 and protected by excellent heat dissipation and enclosure, T906 is ideal for building energy-efficient autonomous machines
With up to 10 Gigabit Ethernet and ultra-long MTBF stable operation, this supercomputer makes advanced analytics possible while providing the ability to handle multiple simultaneous streams from like dozens of IP cameras. It carries Wi-Fi wireless capabilities and supports Bluetooth, 4G & 5G modules configuration, as well as GPS navigation.
Equipped with a JEG vehicle-level connector where there are 3x CAN FD, and 2x GPIO, you can input multiple radar sensors. It has also mounted a GMSL camera connector which you can utilize to build a camera sensor hub, a control unit, or a video transcoding unit. This edge AI box can implement autonomous driving, autonomous mobile robots (AMR), or teleoperation of unmanned ground.
It comes with a rich set of industrial interfaces: 1x standard RS232, 1x RS232 for UART, and 1x RS232 for the Time SYNC trigger.
Covered by super strong and lightweight aluminum alloy, it is designed as IP55 for a high degree of protection and it is designed as passive heat dissipation with two onboard fans for a strong cooling function. With pre-installed Jetpack 5.0.2, this great computing platform is ready to deploy on unmanned cleaning cars, unmanned delivery cars, intelligent inspection, AGV, and other unmanned driving fields.
Module
AI Performance
200 TOPS
CPU
8-core Arm® Cortex®-A78AE v8.2 64-bit CPU
2MB L2 + 4MB L3
GPU
1792-core NVIDIA Ampere architecture GPU with 56 Tensor Cores
Memory
32GB 256-bit LPDDR5
204.8GB/s
Storage
64GB eMMC 5.1
1 x m.2 key m nvme 2280 connector
Display
1*HDMI Type A
Video Encode
1x 4K60 (H.265)
3x 4K30 (H.265)
6x 1080p60 (H.265)
12x 1080p30 (H.265)
Video decoder
1x 8K30 (H.265)
2x 4K60 (H.265)
4x 4K30 (H.265)
9x 1080p60 (H.265)
18x 1080p30 (H.265)
Gigabit Ethernet
1x 10GbE
1x 1GbE
Wifi/BlueTooth
1x M.2 KEY B (2230) Support WiFi/Bluetooth
1x M.2 KEY E support 5G
1 mini PCIe for 4G
(modules not included)
GPS
Support GPS (modules not included)
USB
4x USB 3.0 Type A Connector;
1x USB 2.0 TYPE-C port for Device mode;
1x USB 2.0 TYPE-C port for Debug
Industrial Interfaces
3xCAN (with CAN chip)
2xGPIO
2x RS-232 D-SUB9
1 xTIME SYNC(RS232)
Camera
GMSL 2 camera connector (compatible with GMSL1)
RTC
RTC Connector with Rechargeable Battery
FAN
2* FAN
LED
2x Status Indicator LED
Button
Power KEY
Reset KEY
Recovery KEY
OS
JetPack 5.0.2
Power
9-36v JAE(MX23A12SF1)
Typical power 45W Maximum 75W
Mechanical
196.7*196*74mm
2.5kg
-20℃-55℃
Hardware overview
Application
  • Autonomous Machines
  • Unmanned vehicle for cleaning & delivery
  • AGV(Automated Guided Vehicle)
  • Individual service for shopping mall
  • Robots for factory & warehouse
  • Intelligent inspection
  • Mapping & Planning for consultation
x1
Mounting Bracket
x1
19V Power Adapter
x1
Power Adapter Cable
x1
Type-C cable
x1
1. How come my VGA to HDMI connector doesn't work?
Currently, the HDMI port does not support the transmission of HDMI signal.
2. What kinds of 4G/5G/WiFi modules can I use?
Module tested
4G
Neoway n720 / Quectel EC20
5G
Quectel RM500Q-CN
WiFi/BT
AzureWave CB375
GPS
HSTAR HX-26-GN-3X
認証
HSCODE8471419000
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
Mini AI Computer T906 - with Jetson AGX Orin 32GB
SKU 114110168
T506S
JPY¥411354.00
廃番
product.detail.alsoAdd.title
