おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Highly-integrated Includes frameless torque motor, absolute encoder, driver circuitry and planetary reducer
  • Simple connection Needs only one XT30(2+2) cable for power connection and control communication (CAN) interface
  • Dual Encoder Enables multi-turn position recognition
  • Battery power compatible Could be used in 24V battery-powered system
  • Daisy-chain capable Can connect multiple actuator modules in series using XT30 cables for robotics applications
仕様
Product
Myactuator X4-10 Motor
Rated Voltage
24V
Operating Temperature
0℃~50℃
Mechanical Dimension
55mm x 55mm x 61mm
Communication Interface
CAN
Gear Ratio
1:12.6
Rated Output Power
100 W
Rated Torque
10 Nm
Peak Torque
19.5 Nm
Pole pair
13
For more information, please see datasheet
Motor Load Characteristics Curve
ハードウェア概要
用途
  • Robot Arm
Please contact customer service for arm's reference design (STEP file) after purchase
認証
HSCODE8501310000
USHSCODE8501316000
UPC
EUHSCODE8501109390
COOCHINA
部品リスト
x1
XT30(2+2) Cable
x1
Myactuator X4-10 1:12.6 Motor CAN
SKU 114090069
Myactuator X4-10 motor is a highly-integrated planetary actuator module that includes frameless torque motor, absolute encoder, driver circuitry and planetary reducer. The module has 1:12.6 gear ratio, with 10 N.m peak torque. The module is perfect for rotobtics applications such as robot arm and humanoid robots. It can be controlled through CAN interface.
USD$345.00
product.detail.alsoAdd.title
