When setting up a LoRa Network the positioning of the Gateway and the Antenna may strongly influence the coverage. When you use a fiberglass antenna to further improve the coverage. This CFD200 cable with a 3m length could enable you to extend the distance between the device and the antenna therefore you could have more positioning flexibility. It is also waterproof and can withstand harsh outdoor environments.
Electric Characteristics | |
Frequency | DC~ 6 GHz |
Impedance | 50 Ohm |
S.W.R. | <= 2.0 |
Insertion Loss | <= 1.5 dB @ 3 GHz |
Voltage (breakdown) | > 500V |
Insulation Resistance | >= 15 M ohm |
Center Conductor Contact Resistance | <= 60 m ohm |
Outer Conductor Contact Resistance | <= 25 m ohm |
Material & Mechanical Characteristics | |
Material of Conductor Brass (Cu) Pull Test of N Connector | >= 5 Kg |
Pull Test of RP-SMA Connector | >= 3 Kg |
Mating Cycles | > 500 |
Environmental | |
Operation Temperature | -40˚C~+65˚C |
Storage Temperature | -40˚C~+80˚C |
N-type to RP-SMA male Cable with 3m length to connect a LoRa Gateway to a fiberglass antenna.
