This is NVMe M.2 2280 Internal SSD with 1TB capacity, which also includes a cooling fin.
Here comes NVMe M.2 2280 Internal SSD with 1TB capacity, compatible with Desktops and laptops that accept PCIe NVMe Gen 3x4. It includes a cooling fin which is applicable to all 2280 SSDs.
Specifications | KIoXIA |
Capacity | 1TB |
Interface | PCI Express Base Specification Revision 3.1a (PCIe) |
Interface Maximum Speed | 32 GT/s (PCIe Gen3 x4) |
Interface Command | NVM Express Revision 1.3c command set |
Form Factor | M.2 Type 2280-S2-M |
Flash Memory Type | BiCS FLASH TLC |
Dimension (Max:L x W x H) | 80.15 mm x 22.15 mm x 2.23 mm |
Drive Weight | 500GB, 1TB: 6.8g (typ.), 2TB: 7.1g (typ.) |
Max Sequential Read Speed | 2,100 MB/s |
Max Sequential Write Speed | 1,700 MB/s |
Max Random Read Speed | 1TB: 400,000 IOPS |
Max Random Write Speed | 2,400,000 IOPS |
Endurance (TBW) | 1TB: 400 TB |
MTTF | 1.5 million hours |
Operating Temperature | 0°C (Ta) to 85°C (Tc) |
Storage Temperature | -40°C to 85°C |
Shock Resistance | 9.806 km/s² [1,000 G], 0.5 ms half-sine wave |
Supply Voltage | 3.3V ± 5% |
Vibration | 196 m/s² (20 G Peak, 10~2,000 Hz, 20 min / Axis) x 3 Axis |
Power Consumption (Active) | 1TB: 3.5 W (typ.) |
Power Consumption | PS3: 50 mW (typ. PS4: 5 mW (typ.) |
PCI Express | Compatible with PCI Express Base Specification Revision 3.1a NVM Express Revision 1.3c command set |
Connector Type | M.2 M key Socket |
Target Applications | Client desktops and laptops |
NVMe M.2 2280 SSD 1TB | x1 |
Cooling fin | x1 |
| HSCODE | 8471701100 |
| USHSCODE | 8523510000 |
| UPC | |
| EUHSCODE | 8517180000 |
| COO | CHINA |
