製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Powered by 11th Gen Intel® Core™ i3 1125G4 CPU running up to 3.70GHz and Intel UHD Graphics 48EUs running up to 1.25 GHz
  • Rich peripherals including dual® 2.5-Gigabit Ethernet ports, USB 3.2 Type-A port, USB 2.0 Type-A port, HDMI port and DP port
  • Support hybrid connectivity including 5G, LoRa, BLE and WiFi (5G, LoRa, BLE and WiFi need additional modules)
  • Dual SATA III 6.0 Gbps data connectors for hard disk drives
  • Embedded Arduino Coprocessor ATSAMD21G18 32-Bit ARM® Cortex-M0+
  • M.2 B-Key/ M-Key/ E-Key for expandability such as SSD, LTE/4G/5G/LoRaWAN/WiFi/BLE modules
  • Support both Windows OS and Linux OS
ODYSSEY X86i31125G4, as one of the main cores of reServer series, is a high-performing yet cost-efficient board from the edge to the cloud.
By supporting both Windows OS and Linux OS, ODYSSEY-X86i31125G4 allows you to build applications efficiently and easily no matter for  commercial, industrial, or other uses.
ODYSSEY X86i31125G4 is an ODYSSEY X86 v2 board and powered by the quad-core Intel® Core™ 11th Gen. i3 1125G4 running up 3.70GHz and Intel UHD Graphics 48EUs (400 - 1250 MHz) running up to 1.25GHz, which delivers high CPU and AI performance for various applications.
It comes with two high-speed 2.5-Gigabit Ethernet ports and supports hybrid connectivity including 5G, LoRa, BLE and WiFi. It enables up to 250% faster performance than Gigabit Ethernet with compatible hardware and provides the transition speed up to 5Gbps using link aggregation.
ODYSSEY X86i31125G4 is equipped with a large scale of heatsink to ensure stable operations under heavy load, while providing excellent heat dissipation to enable the power of CPU.
Having dual SATA III 6.0Gbps data connectors, ODYSSEY X86i31125G4 is able to equip up to two SATA hard disk drives to acquire more storage.
It also has M.2 adapters to connect to various SSDs for faster read and write speeds.
* SATA Hard Disk Drives are not included. SSD is not included in some versions.
There is an onboard ATSAMD21 Core, an ARM Cortex-M0+ MCU that allows you to program Arduino on the x86 platform, which provides endless possibilities of using the X86 i3 1125G4
The X86 board supports LoRa technology which makes it possible to connect to a wide range of sensors. It can be applied as an edge computing center for all scenarios that require vast data to collect and process at the edge. The expandability of 5G technology is useful in places where there isn’t always reliable internet connectivity, such as on a farm or in a location with spotty service.
*To get LoRa and 5G connectivity, optional modules are needed.
Place it in the artistic, suitable enclosure which is of the compact and delicate structure to have a neat work space
Specifications
VersionsBasic VersionsHigh Performance Versions
PlatformProcessorIntel® Core™ 11th Gen. i3 1115G4Intel® Core™ 11th Gen. i3 1125G4Intel® Core™ 11th Gen. i5 1135G7Intel® Core™ vPro® 11th Gen. i5 1145GREIntel® Core™ vPro® 11th Gen. i7 1185GRE
Cores/Threads2C/4T4C/8T4C/8T4C/8T4C/8T
FrequencyUp to 4.10 GHzUp to 3.70 GHzUp to 4.20 GHz1.50 GHz ~ 4.10 GHz1.80 GHz ~ 4.40 GHz
Co-processorMicrochip® ATSAMD21G18 32-Bit ARM® Cortex-M0+ @ 48MHzRaspberry Pi® RP2040 32-Bit Dual ARM Cortex-M0+ @ 133MHz
MemoryTechnologyDual Channels DDR4-3200
CapacitySupport up to 64GB
ECC Memory SupportedNOYES
GraphicsControllerIntel® UHD Graphics 48EUs (400 - 1250MHz)Intel® UHD Graphics 48EUs (400 - 1250MHz)Intel® Iris Xe Graphics G7 80EUs(400-1300MHz)Intel® Iris Xe Graphics G7 80EUs(400-1300MHz)Intel® Iris Xe Graphics G7 96EUs(400-1300MHz)
Advanced TechnologiesIntel® vPro®NOYES
Intel® Total Memory EncryptionNOYES
NetworkControllerIntel® Ethernet Controller I225-VIntel® Ethernet Controller I225-LM
WirelessWiFiM.2 E-Key(PCIE & CNVi Support), Intel® Wi-Fi 6 AX201(Optional)
BluetoothBluetooth 5.0, BLE(Optional)
DisplayLCDeDP 40-Pin 4 Lane Connector
HDMI1 x HDMI 2.0b, up to 4Kx2Kx24bpp@60Hz
DP1 x DP1.4a 7680x4320x24bpp@60Hz
Multiple Display4 simultaneous displays with each display interface combination
External I/OEthernet2 x 2.5GbE LAN ports (RJ45, supports 10/100/1000/2500 Mbps), Intel® i225
HDMI/DPOne/One
USB Type-CN/AUSB PD / USB 4.0 / Thunderbolt 4
USB Type-AUSB2.0 Type A x1 ; USB3.2 Type A x1USB2.0 Type A x2 ; USB3.2 Type A x1
LEDPower Status
Power Supply1x5.5x2.5mm DC Jack / Wafer 2.0mm 8pin
Micro Sim Card Slot1
Internal I/OSATA2 x SATA Gen III 6.0 Gb/s Data Connectors + 3 x SATA Power Connectors
COM Port1 x RS-232/422/485, 1 x RS-232
GPIO28-Pin Arduino Co-processor 2.54mm header30-Pin Raspberry Pi Co-processor 2.54mm header
AudioRealtek High Definition Audio, Microphone + headphone Combo Connector
USB2.0USB2.0 9-pin Header x2 480Mbps
Fan2 x 12V 4-wire Fan header, PWM Control
Front Panel ControlPower-on, Reset, Power Status LED, SATA Status LED
S/PDIF3-Pin 2.54mm Header
SATA PowerWAFER4-Pin 2.0 pitch Connector
Co-CPU. Debug Port6-Pin 0.5mm FPC Connector (SWD)
ExpansionM.2 M-Key1 x M-Key 2242/2280(PCIe 3.0 x4)
M.2 E-Key1 x E-Key 2230(PCIe 3.0 x1; USB2.0 x1;Intel CNVi)
M.2 B-Key1 x B-Key2242/2252/2280(PCIe 3.0 x2; USB2.0 x1)
High Speed I/O1 X PCIe x4 Gen41 X PCIe 3.0 x4/SMBus/LPC/USB 2.0/CPU GPIO etc.
PowerSupply VoltageDC Jack: 12VDC Jack: 12V-19V
RTC BatteryLithium 3V/210mAH
CertificationEMCCE,FCC,KC,TELEC
Hardware Overview
ODYSSEY-X86i31125G4 x 1
User Manual x 1
Screwdriver x1
認証
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471800000
COOCHINA
ODYSSEY-X86i31125G4 Powerful Edge Platform powered by 11th Gen Intel® Core™ i3 1125G4
SKU 102110608
ODYSSEY X86i31125G4 is an ODYSSEY X86 v2 board and powered by the quad-core Intel® Core™ 11th Gen. i3 1125G4 and Intel UHD Graphics 48EUs (400 - 1250 MHz), which delivers high CPU and AI performance for various applications. The x86 board has two high-speed 2.5-Gigabit Ethernet ports and supports hybrid connectivity including 5G, LoRa, BLE and WiFi. There is also an onboard ATSAMD21 coprocessor, an ARM Cortex-M0+ MCU that allows you to program Arduino on the x86 platform.
JPY¥58403.00
