製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Odyssey Blue J4125 128 GB is a powerful mini PC with super low power consumption. It’s a perfect device for personal, commercial, and industrial applications. You can use it as office equipment such as a desktop PC, NAS, router, or a home server for 4K media theater, NVR, Home Automation, gaming PC, and many more! The compact and stylish design will keep your desk clean and neat.
It's small, it's inexpensive for a fully activated Windows system or Ubuntu desktop. We also have Windows 10 pre-installed. Just simply connect it to a mouse, a keyboard, and a monitor with the ODYSSEY Blue, not a Windows users? Install your favorite Linux distribution! We also have abundant keep updating tutorial resources including home server applications and also OS installastions.
Odyssey Blue J4125 comes with re_computer blue case, pre-installed Windows10 (unactivated), and 128GB SSD. If you don't want the case, you can buy other versions with the board only.
  • Fast processor: Intel® Celeron® J4125, Quad-Core 2.0-2.7GHz and Intel® UHD Graphics 600
  • Integrated Arduino Coprocessor ATSAMD21 ARM® Cortex®-M0+
  • Hybrid connectivity: Dual-Band 2.4GHz/5GHz WiFi, Dual Gigabit Ethernet, LTE capability with additional module
  • Install whatever OS you like: Pre-installed Windows 10 (Unactivated), support Linux OS.
  • Plenty of I/Os: Raspberry Pi 40-pin GPIO, Arduino headers, M.2 PCIe, SATA III, USB 2.0, Micro SD card slot; SIM Card slot, etc
  • Stylish mini PC with transparent acrylic re_computer case
Applications
Office PC/ NAS/ Soft Router/ Firewall/ 4K Home Theater/ NVR/ Home Automation/ Gaming/ Virtual Machine Monitor, and many more!
It can also be a NAS work with Open Media Vault and FreeNAS, it's both fast and large enough with external SSDs. If you want higher performance and more storage, you can use a standard M.2 PCIe or SATA SSD.
Flashing OpenWrt firmware, you can use Odyssey as the most trusted high-speed router with OpenWrt or OPNSense / pfSense with Dual Gigabit Ethernet. With 4G, even 5G cellular network connectivity via two of M.2 PCIe (B Key and M Key), it can also be a hybrid speed gateway.
Media Server? Of course, let Odyssey steam 4K for you with Plex, and enjoy family sharable entertainment. Plus, without any Ads using Pi-hole!
The J4125 supports Intel Hyper V virtualization and can be virtualized with Promox or VMware ESXi to create multiple instances or install multiple systems which makes it perfect for homelab option. For more information, please check this blog for ESXi installation.
Perfect work with Home Assistant, use Odyssey as your center of private and local home automation.
Connecting to IP cameras, it can also work as an NVR system, even with local processing AI capability with Frigate. (we recommend you can also add Coral AI accelerator for a faster inference, we tested there is 10FPS without Coral, enough tho!)
Also an Arduino fan? Program Arduino with onboard ATSAMD21 Core, an ARM Cortex-M0+ MCU. The ODYSSEY Blue J4125 128 GB is more than just a computer, with the Arduino Co-processor onboard, it can be used to connect with sensors, gyroscope, and much more. Why don’t you start exploring your IoT journey from here! We have over 300 Grove modules and Sensors for you to choose from.
Odyssey Blue has been recognized and featured by leading industry media and community: ArsTechnica, Tom’s Hardware, The New Stack, CNXSoftware, TechRadar, HACKADAY, Notebook Check, Hackster, ExplainingComputers, Android Central, Linux Gizmos, PC Perspective, ETAPrime, and many more!
If you are looking for open source SBC for commercial and industrial needs. Seeed provides customization service based on Odyssey X86 boards. Learn more about customization services and use cases at seeedstudio.com/odm.
Components
Processor
Intel® Celeron® J4125 (Frequency: 2.0 - 2.7GHz)
Coprocessor
Microchip® ATSAMD21G18 32-Bit ARM® Cortex® M0+
Graphics
Intel® UHD Graphics 600 (Frequency: 250 – 750MHz)
Memory
LPDDR4 8GB
Storage
External 128GB SSD
Wireless
Wi-Fi 802.11 a/b/g/n/ac @ 2.4/5 GHz HT160
Networking
Intel® I211AT PCIe Gigabit LAN, Supports Wake-On-LAN, Supports PXE
Audio
Microphone + headphone Combo Connector
USB
USB 2.0 Type-A x2, USB 3.1 Type-A x1, USB 3.1 Type-C x1
Video Interfaces
HDMI2.0a: Up to 4096x2160 @ 60Hz 24bpp / DP1.2a: Up to 4096x2160 @ 60Hz 24bpp
Expansion Slots
M.2(Key B, 2242/2280): SATA III, USB2.0, UIM; M.2 (Key M, 2242/2280): PCIe 2.0 ×4; Micro SD card Socket; SIM Card Socket; SATA III
Operating temperature
 0°C~45°C
Storage temperature
 -20°C~60°C
TPM
Built-in TPM 2.0
Power
DC Jack 5.5/2.1mm or Type-C PD; DC Jack input: 12-19V DC; Type-C input: 15V DC
Dimensions
130x120x50mm
Certifications
FCC, CE, TELEC
Hardware Overview
  • ODYSSEY - X86J4125 x 1
  • User Manual x 1
  • International Power Adapter
  • Antenna x 2(Assembled)
  • RTC Battery x 1(Assembled)
  • Heat Sink(Assembled)
  • Cooling Fan (Assembled)
  • re_computer case x 1
  • External 128g SSD (Assembled) x 1
認証
HSCODE8471419000
USHSCODE8517180050
UPC
EUHSCODE8471800000
COOCHINA
Odyssey Blue: Intel® Celeron® J4125, Quad-Core 2.0-2.7GHz, Win10 Mini PC with 128GB SSD, Dual Gigabit Ethernet NICs
SKU 110991564
Odyssey Blue J4125 allows you to simply build Edge Computing applications with powerful CPU and rich communication interfaces. The Odyssey Blue J4125, based on Intel Celeron J4125, is a Quad-Core 2.0GHz CPU that bursts up to 2.7GHz. There is also an onboard ATSAMD21 Core, an ARM Cortex-M0+ MCU that allows you to program Arduino on the x86 platform.
Odyssey Blue with Coral USB for Frigate
JPY¥42576.00
Customization From 1 Piece
